I have a foxconn ls-36 mobo. w/ (1)256 mb pc100 mem. module. will this board accept (2)- 1 gbyte pc-100 sdram ecc modules or do I have to run non ecc modules. I am getting mixed answers from different people. Thanks, Terry Erickson
  • Terry Herrera May 11, 2010
    include the whole moterboard number and i will be able to help
    Problem Solver:
  • 16 Answers
I don't think it will run that non ecc module.
Posted on Oct 08, 2009
I need to know the capacity for MEMORY AND THE TYPE SPECIFIED
According to the manufacturers specs these are the memory specifications you need, and the maximum the motherboard will accept...
3 x 168-Pin DIMM-socket
for up to 768 MB memory SDRAM
with 8, 16, 32, 64, 128 and 256 MB size
Dec 28, 2010 | Shuttle Slot A AI61 (MBAI61) Motherboard
Dell Optiplex GX110 currently runs 128mb sdram pc125 cl3.0 . Am I correct to assume maximum upgrade would be 2 x 256mb sdram pc133 non-ecc unbuffered 3.3v ? Maximum memory per slot being 256mb ? Is my...
If I remember correctly, that Dell has two memory module slots, so 2 512 mb modules of non-ecc pc133 memory is the max that the system board will allow.
This is controlled by the system board chipset, and not by the bios.
Dec 15, 2010 | Dell OptiPlex GX110 PC Desktop
How can i use 1x2 pc2100r ecc mem modules on an l7vmm3 motherboard
Two 184-pin DDR DIMMs sockets for 2.5V DDR SDRAM (DDR266/DDR200)
Maximum: 1GB (Unbuffered Memory)/ 2GB (Buffered Memory)
Yes, regestered EEC modules are "buffered", so you should be ok at 2 gigs.
Nov 23, 2010 | EliteGroup ECS MB L7VMM+ W/ CPU-ATHLON...
I got a computer handed to me with a asus P2B-f motherboard, works well, but running win98, may upgrade right away HOWEVER very slow with 128MB SDram win98 wont allow for the flash/adobe required to run...
Here is the manual for that board:
http://www.csslabs.com/static/download/cds/112/Mobo/ASUS_P2B-BX/Manual/Mb-p2bf.pdf
You must use 3.3 Volt unbuffered 168 pin SDRAM. Each slot (total of 4 slots) can have up to 256MB for a total of 1 GB.
Most local used computer shops will have this kind of memory (used, of course), probably at $10 or $20 a stick.
This memory is also available new (just don't buy anything over 256 MB per stick):
http://www.compusa.com/applications/category/category_slc.asp?CatId=145&name=SDRAM&
You can use PC100 or PC 133. You can also use ECC or non-ECC. Non-ECC is more common.
Aug 16, 2010 | Computers & Internet
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
I have a p4i45g MB with a p4 Processor. Do i use
- Max. capacity of system memory: 2GB DDR or 2GB SDRAM
- DDR x 2, DDR 266/200 non-ECC, un-buffered memory
- SDRAM x 2, PC133/100 non-ECC, un-buffered memory
use DDR1
Jul 14, 2009 | Computers & Internet
Memory module
0 MB on-board memory expandable to 512 MB
Two SO-DIMM slots
SO-DIMM sockets accept 8-, 16-, 32-, 64-, 128-, and 256-MB SDRAM modules in any combination.
Use only PC100 memory modules.
so yeah you bought the wrong ram
Mar 09, 2009 | Dell Inspiron E1505 Notebook
How much memory the motherboard ASUS INTEL 815E CUSL2-M SUPPORT?
no you couldnt, the max supported ram on the board you have is 512
Maximum 512MB PC133/PC100 non-ECC SDRAM
http://www.motherboard.cz/mb/asus/CUSL2-M.htm
Dec 10, 2008 | ASUS Intel 815E Chipset CUSL2-M...
Max ram for SY-K7VEM PRO
Two SDRAM DIMM sockets support up to 512MB
168-pin PC133/PC100 non-ECC, unbufferred SDRAM memory
This is what your M/board can use in memory
Aug 20, 2008 | Soyo Sy-K7Vem-Pro Motherboard
I have a P3 at 500MHz and was wondering with this Motherboard,
The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
The motherboard supports the following memory features:
  • 168-pin DIMMs with gold-plated contacts
  • 66 or 100 MHz SDRAM
  • Non-ECC (64-bit) and ECC (72-bit) memory
  • 3.3 V memory only
  • Unbuffered Single- or double-sided DIMMs in the following sizes:
DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
So the max you can go is 3 x 256 MB.
Thanks and please take a moment to rate fixya.
Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
Computers & Internet Logo
576 people viewed this question
David Payne
David Payne
