Question about NetGear WGR614 Wireless Router
A random guy came in and setup a home network for us using a Netgear Wireless router (WGR614v6). We have a PC on main level, an iMac and laptop in the basement that connect wirelessly and without any trouble. The PC on the second level connects directly to the router and the router connects to the cable modem. Recently the hard drive on that PC died and was replaced. Now the PC doesn't recognize the router. I am not good with networking... please help!
  • 2,260 Answers
Hi whioch computer has a problem ?
A PC with the new hard drive ?
Mkae sure that you have the wireless adapter working on the computer.
If it is working then try to find the network .
Click Here for more info about wireless network.
Posted on Oct 08, 2009
  • Prashant M
    Prashant M Dec 05, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
Is there a way to setup my wireless network without connecting a computer directly to one of the router Lan ports? I would like to locate my router and cable modem in the center of my house on the main...
it is a good idea to have your pc plugged into the router during setup. with a wireless connection, you may loose your connection during setup since many routers need to "reboot" after changes are made. after the initial setup, making minor changes via wifi are acceptable.
Dec 12, 2010 | NetGear WNR2000 Wireless Router
Connecting my Home Hub to Netgear to have wireless setup
3ee198b3c15f6ca7320d6cda56a651c7.png Netgear DG834G 54 Mbps Wireless ADSL Firewall Router Set-up Guide _________________________________________________________________________________________________ _________________________________
Oct 05, 2008 | NetGear DG834G Router
I can not connect to my netgear wgr614v6 with my hp netbook. I can connect with my other laptop and the netbook has been connected before. It keeps saying "acquiring Address"
If you're trying to connect wirelessly, and it says "acquiring address" and never connects, it's most likely because your wireless network has an encryption key enabled, and the encryption key on your laptop/netbook doesn't match. You should disconnect from your home wireless network, and then try to re-connect to it. Verify that you're using the correct wireless key to connect. If that still doesn't work, you should reset your router to factory defaults so that there's no wireless key required to connect - and then try again. If you want to put the wireless key back, you can run the CD or connect to the router using the web interface and configure it again.
Mar 07, 2010 | NetGear WGR614 Router
Sorry if this seems a repeat question but I can not find the answer on here... I have a Netgear 54 Mbps wireless router WGR614v6. When I plugged it in, it does not have a wireless signal. Please note that...
for the laptop to detect the router you need to install the router's driver in you laptop and follow the instructions while installing since its a new laptop it always need to be configured.
Jan 01, 2010 | NetGear WGR614 Wireless Router
Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Feb 11, 2009 | NetGear WGR614 Router
Netgear wgr614 v6 As Bridge for XBOX
I'll take a stab at this. It's a bit difficult because I don't know what your level of expertise is. You're actually using the Netgear wireless ROUTER not a bridge. Your ISP can use a couple of methods to give you service. DSL companies like Verizon probably use PPPoE which require you to login and provide a password and VZ is notorious for closing down port 25.
O.K. Did I mention I don't like them very much? Anyway, I'm going to give you a link to Netgear's excellent web site for configuring a router and the XBOX connection. This is the whole list of v6 compatible instructions. Note the very bottom link to use Netgear routers with XBOX.
http://kbserver.netgear.com/products/wgr614v6.asp
Note under the Troubleshooting topic that there is a configuration and two setup files, depending on what you're connecting to, and some tips on what to do if it doesn't work.
It's not as bad as it looks.
Carl
Jan 04, 2009 | NetGear WGR614 Router
The microsoft wireless adapter on my Xbox360 does not connect to my wireless network
How Can I connect a network adapter from my room to downstairs about 20 yards away?
I need XBOX LIVE badly, everyone has it cmon FIXYA help me out on this.
The router downstairs is a TalkTalk modem help me!
Jun 28, 2008 | Computers & Internet
After installing netgear router and wg111v2 it has slowed my pc down laptop fine tho? can you help pc is the main home pc and laptop is seconary?
Dear Customer,
Yes It will happen,cause of protocols handling on router with your main pc,
SO,try to use another higher configured pc or you can use server like pc,
Never try to handle router on lower configured pc ,its affect on you r work ,its defanetly very slow-down you work,
SO try my solution you will get more speed,
THNX
May 22, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear Wireless Router WGR614v6
so chitodel click on start button
then CONTROL PANEL>NETWORK CONNECTIONS> right click WIRLESS CONNECTION>PROPERTIES>in GENERAL tab click on INTERNET PROTOCOL>PROPERTIES and then click OBTAIN AN IP ADDRESS & OBTAIN DNS SERVER ADDRESS AT LAST CLICK O.K. this will help u try it now..........................
GOOD LUCK.
Feb 06, 2008 | NetGear WGR614 Wireless Router
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
NetGear WGR614 Wireless Router Logo
98 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
