Question about Canon Office Equipment & Supplies
Printer won't respond to scan command (pixma mp450) and keeps telling me the cover is open when it is clearly not!
  • 117 Answers
Press the OK button to
exit the error, and do
the print head
alignment again (from
printing of the print
head alignment sheet),
while confirming the
following:
- Set A4 or LTR size
plain paper.
- Confirm that the print
is printed properly
(no smear or nonejection
of ink).
- Fill in all the
applicable boxes in
the printed sheet.
- Place the sheet on the
platen glass in the
correct position and
orientation.
Posted on Oct 09, 2009
I need to scan pictures. I have a cannon pixma mp450 Thanks~! Alexandra
1. Go to window "start" button.
2. At the star manu, select, "Program"
3. At the program manu, select "Accesorries"
4. At the accesorries manu, select "Clipboard"
5. Clipboard will be opened.
6. At the "File" manu, you can see "Scanning" option.
7. Select it, and you will see the scan process.
Apr 25, 2011 | Canon Pixma MP450 All-In-One InkJet...
Erreur 5b00 sur canon pixma mp450
1. Turn off the printer ( "Power" button).
2. Open printer cover and hold the button "Resume" (red circle in the triangle) and push and hold Power button.
3. Release button "Resume" and then push button "Resume" 2 times and release both buttons.
4. When printer become ready on the display write "CANON Idle".
5. Now close printer cover and push button "Resume" 4 times.
6. Then push "Power" button 3 times to turn off printer.
All done. The printer is ready to print.
Dec 28, 2010 | Canon PIXMA MP450 All-In-One InkJet...
How do you replace an ink cartridge in the pixma mp450
open upper cover ink assy must be in the window, hold firmly the ink and full, replace the same way.
Mar 25, 2010 | Canon Pixma MP450 All-In-One InkJet...
My new canon pixma MP450 has an error code of 6500 on the display panel. Can you please tell me how to fix it
this is printer logic motherboard problem
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 13, 2010 | Canon Pixma MP450 All-In-One InkJet...
I have a canon pixma mp450 printer that shows an error code of 6000 that will not clear itself no matter what I do. How do I fix this problem and what is it?
It may be
How To Reset Waste Ink Canon Pixma MP450
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 02, 2009 | Canon Pixma MP450 All-In-One InkJet...
When I try to print,it keeps on saying that my printer is not
make sure your MP450 is your default printer..go to start menu>control panel>printers...then at MP450 icon, do a right click and choose set printer as default...then try to open up your work again to make sure it is refresh and try to print....see the result...
hope this can help u..n if it is function, please choose it as FixYa!
Apr 18, 2009 | Canon Pixma MP450 All-In-One InkJet...
Canon Printer Problems
Open the printer, locate the absorber, wash it, then centrifugate to get it dry, install it again and reset the printer.
The absorber is like a sponge filled with ink when it's used.
Apr 30, 2008 | Canon Pixma MP450 All-In-One InkJet...
Can Not Scan!!!
This is respond to edid96, I try to fix by reinstall my software which came with the printer's software just try this first and see if the problem is fixed.
Apr 12, 2008 | Canon Pixma MP450 All-In-One InkJet...
201 people viewed this question
old marine
old marine
