Question about Microsoft Xbox 360 Console
My 360 wont read the disc
When i turn on the console it all goes smooth untill it tries to spin the disc i think cause it always comes up open tray...if i do that for ahour or so the thing reads it...
    Problem Solver:
  • 18 Answers
Repairtech99's right same thing on mine i tried what he said and now my 360's healthy again
Posted on Oct 15, 2009
  • 767 Answers
The laser is suspect , but if you can get it to read
than I believe you may have worn bushings in
the spindle motor .
If you open your unit up ,then remove and open the CD rom
drive up , the spindle hub should turn with very little resistance
if it stiff then turn it upside down and take a Q-tip with a soaking of
wd40 and poke it around the underside of the hub and
some times you can free them up enough to get a little more
mileage. Make sure to dab off all of the excess WD-40.
Just some tip/trick
Rob
Posted on Oct 09, 2009
    Problem Solver:
  • 5 Answers
It's probably the laser call microsoft and they will tell you what to do
Why wont my xbox 360 elite read discs? i put disc in and it comes up reading and then open tray
My only questions are does the console say the discs are damaged in any way? and is the console standing up right?
If the discs are scratched in any way then that might cause the 360 to not read the disc and sometimes having a console play the disc upright (example of upright 360) for a long time can cause dis function when trying to play discs, so try playing the discs with the console on its side (side example) These are my solutions to the problem but you can try these: Solution 1 Solution 2
Mar 13, 2011 | Microsoft Xbox 360 Elite Console
I have the... the... the... OPEN TRAY ERROR
I get this at times, I find you just have to keep putting discs in untill it reads one, if it dosn't then im afraid you'll need a new one, just check if your under warrenty before buying one, because if you are you can get it fixed (or if it can't be fixed, a replacement) from Microsoft for free.
Apr 08, 2010 | Microsoft Xbox 360 Console
Disc wont play. cant read disc and says open tray when disc is inserted
Just open the tray close it clean the disc turn it inside again it will work, i alway get this with CoD:WaW. But with all my other games it just works fine maybe there is something wrong with your disc and the console cant read it change it for another one sell it and buy a new one or just try my solve problem. Hope this helped!
Sep 12, 2009 | Microsoft Xbox 360 Console
Disc Reader not reading disc
You can try to Clean with dvd cleaning kits...if doesn´t work..the only way fix is to disassemble the 360 and force the dvd laser adjusting the micro pot...located under the laser unit..But you will loose warranty and I think that the best way is to send your game console to microsoft...what hurts is that $140,00 you can buy 02 or even 03 xbox drives on ebay. Choose the best way! Good Luck!
Sep 10, 2009 | Microsoft Xbox 360 Console
Wont read games. Console says insert game into xbox 360 or open tray.
you might need to clean your laser, if they get dirty from playing games they won't read anything. When you put a game in the laser flashes once to read what type of disc is in, if its dirty it wont read anything and thinks there is no disc in it. If cleaning it dosen't help then you might just have to replace the laser. They aren't overly expensive and they are pretty easy to install as well.
Aug 09, 2009 | Microsoft Xbox 360 Console
Wont play/read any xbox games
1 dirty lens
2 dirty disc
3 programme error
1 i think the xbox cleans its own lens but check the manual if not get a good lens cleaner.
2 clean the disc always clean your discs after and before you use them.
3 take off your hard drive and any memory cards and reset xbox to factory settings
May 12, 2009 | Microsoft Xbox 360 Elite Console
My XBOX 360 elite is not reading discs.
sounds like your Disc Drive has taken a **** I have had the same issue and I had to open it up to make the drive start to spin again
Mar 29, 2009 | Microsoft Xbox 360 Elite Console
Loading games
You cant replace the drive they are locked to the motherboard!( wont work on other motherboards) Well you could spoof it to think that the new drive is the original. This is not easy stuff to do 1 mess up and you have yourself a 400.00 paper weight or a bricked drive.
You could open it up and try the rubber band trick, that's for modded boxes that are having trouble reading certain media types"discs".
Remember if you open your 360 you void the warranty.
Oct 12, 2007 | Microsoft Xbox 360 Console
X box 360 broke
The only solution really is to open your 360, open the DVD drive and try to see if you can posibibly unfreze the drive. Its possible that you are going to have to put a new drive in it. I would just send your console off, even though you'll have to wait on the Halo experience. If you do open your console, you're going to void your warranty and Halo may cost you a whole 'nother $300. When and if you open your console, you will need to check if the laser is operational. With the console open (check Google for a huge list of how-to-open-it guides) go on ahead and remove the cover from the DVD drive, but keep the DVD drive still placed in the Xbox 360. Hook-up your power and video cable and go ahead and press the eject button (you can place this back on without putting the console back together, even though its ness. to take it off during the disassembly) and watch the tray. Listen and watch for any resistance, stuttering, swaying to one side (hold the console flat), and scraching. It should be very smooth and automatic. Then procede to close the tray but this time watch the laser. Don't look directly over the laser, but try to catch if it lights up (red) and it may even move a little at you. Again, everything should be smooth and automatic. Now for the slightly tricky bit. Take the worst possible game in your collection (King Kong?) and place it on the open tray (open tray, place disc on tray) and then close the tray. Hold the 360 as flat as possible or don't hold it at all (the latter option is better if you have a table nearby) and watch the disc, always ready to press the eject button if something goes wrong and your disc spins out of control and/or you hear scratching. An alternate, safer method of checking to see if the disc spins is to take a fridge magnet and place it on the center spindle magnet and let the disc spin (the magnet, just like the one in the DVD drive cover, hold the disc in place as it spins at super-sonic speed!). Just use the very simple process of emiliation to determine the root cause of your DVD drive problems and then repost. Just remember that this voids your warranty and only open your console if you're sure that you want to try to fix it and you are willing to accept that you may be left with a brick afterwards. That's it for what you should do to diagnose the problem, good luck!
Sep 30, 2007 | Microsoft Xbox 360 Elite Console - Black
Microsoft Xbox 360 Console Logo
109 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
