Shows error code T-2 how can i fix or reset this
  • gmelton282 Oct 08, 2009
    This is a riso FR 3970 high speed printer
    Thank You I will try this and let you know what happens
  • 10,515 Answers
Is it copier. If yes - Make and model of the copier so that we can work together to fix it.
Thanks.
Posted on Oct 08, 2009
  • taran_2005
    taran_2005 Oct 08, 2009
    This error usually refers to the elevator tray. Try taking the paper out and pressing the all reset button on the panel.Sometime is usefull to take a look at circuit of the safety switch of elevator area. If it is open you get T2.
    Before that unplug the printer. Then plug in after few minutes to check the same.
    Let me know, if need further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
Is cannon ir 2200 the shows me error E000051-0000. How can restore it
clearing error code E000051-0000 in canon IR2200
Try to reset the printer follow this stepTo reset the error
1. Additional functions (push)
2. Function (choice)
3. Error (choice)
4. Error code choice (wait)
5. Reset (push)
6. Right power supply off
7. Right power supply on
Oct 24, 2015 | Cannon Office Equipment & Supplies
Error code c6020
you need to reset the fixing unit. go to mode and input 163 then start off then on.
Feb 28, 2014 | Kyocera Mita Office Equipment & Supplies
Error Code E05 Canon MP258
Error Code E05 Canon MP258 may solve by the following steps.
1. Press Stop/Reset button for 5 seconds.2. After five seconds release the button.3. Now your printer will start its process and it is ready to use... thanks
Sep 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Jun 06, 2009 | Office Equipment & Supplies
Irc3200 will not boot up
A E0000-001 is a fuser error code.... You may be able to reset it. Press the "Additional Funcation" botton, then the numbers "2" & "8" at the same time, then press the "Additional Funt." botton. The display will change. To reset the code press Funcation, then CLR. then ERR , then press the "OK" on the display. Then turn the Main power "OFF" then back "ON". If this code shows up alot, you may have a power problem, if the code reset. If it will not clear you have a problem with the fixing unit. Good Luck...
May 26, 2009 | Canon imageRUNNER C3200 Copier
Printer shows error CH551
Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
May 21, 2009 | Ricoh Aficio 1013F Copier
Error Message on copier.
Probably a thermistor problem, dirty or out of position or failed. Could be thermostat too.You will want to check that fuser out first before you reset any codes. Checking for paper, sensors, etc...
If all is clear in the fuser then:
With the power off, hold the 2 and 5 button on the panel and turn the power on. In the display you will see, there are 1-12 choices, choose 1, Software SW. You will see a display of numbers (01-0:1 03). Change the first number to 03, change the second number to 01, change the third number to 00. Press RETURN on the display. Power the unit off, then on. Codes should be reset.
If after resetting the code and powering up machine -- if code comes back then replace the above mentioned.
Jan 23, 2009 | Office Equipment & Supplies
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
My Canon Pixma MP170 printer is showing error code 5800, What must i do to fix this?.
MP170 (5b00) Ink Tank Full Error Reset
1,power off.
2,hold stop/reset ,hold ON/OFF
2,release stop/reset, push stop/reset twice, quickly, then release ON/OFF
3,wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
4,then push power twice, quickly
5,power off and power on.
Jul 15, 2008 | Office Equipment & Supplies
jasbo
jasbo
