Question about Dell Computers & Internet
Sound wont work on my new dell a546s
Sound wont work on my new dell a546, i have tried new drivers, the speakers work on other computers ive tried to reset them, im stuck
  • 24 Answers
Hi ,
Can you be more specific ?
Are you performing clean install ? In this case I believe it is hotfix issue, but on other hand if you do not have this hotfix windows will not install driver for audio. anyways this is not a bad thing to have, so install it and then try to install driver again.
http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/Microsoft-UAA-Bus-Driver-for-High-Definition-Audio.shtml
Posted on Oct 08, 2009
Hello, i have a dell Windows vista and my companion bose 5 wont work.. and ive tried it in another computer and it still wont work. what can be the problem?
Is there any system to which you can connect your BOSE *and* have it work?
If not, then check that the BOSE is getting electrical power into it.
Jul 19, 2011 | Bose Companion 5 Multimedia Speaker System...
I have a set of Logitech speakers s150 USB and Ive had them for about over a year and about a few days ago they were working fine...but now they just won turn on. usually i just unplug them and replug them...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
you might have to get a portable usb sound card if you mean dont have a sound card installed
also try this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or
hope this helps
May 17, 2011 | Logitech S150 2 Speakers
Dell speakers w/ HP computer - connection failure
Your HP computer may need the Drivers from the Dell Speakers to work properly.
Jun 19, 2010 | Dell A215 Computer Speakers
JBLPro Compac computer speakers wont work
Well from what you said no device, it was not detected because of your new magic jack. There might be a conflict in your hardware. Try scan plug and play devices if it can detect your jbl or reinstall both you devices.
Nov 30, 2009 | Computers & Internet
Different speakers, still says i have audio, but no sound
if you look device manager and there is not yellow sign (in speaker sign) your stal sound driver is correct. if not ok right mouse click in speaker then u can up date driver. driver of sound keeping bord cd.
2/ type on run as "control" then go on speaker and sound(diffrent computer hav different sign) and look setting and correct setting.3/ your speaker may be damage check it on other computer and c desk4/ if u not do sound setting in mute?
Jul 10, 2009 | Dell A215 Computer Speakers
Speakers Plugged In Right But Wont Turn On??
If the power light on the speakers isn't on, then the power supply going to the speakers is either in a bad outlet (test the outlet with a voltage meter) or the plug isn't firmly seated. Best of luck in your new home and hope this solves your problem.
Greg
Jun 09, 2009 | Altec Lansing ADA 215 Computer Speakers
Need drivers for bx1121 altec lansing speakers
Go to support.dell.com and type in your service tag where it says "Drivers and Downloads." From there you should be able to find the driver that your computer is somehow missing...
Apr 24, 2009 | Audio Players & Recorders
My speakers wont work
lorcan,  please tell us in detailed, try this, open your speaker volume to the maximum level, then touch the metal side of your phone jack which should be connected to your pc, if your speaker sound such as whistling or something that weired, your speaker should working normally. check your pc for muted sound and driver.
Jan 24, 2009 | Dell A215 Computer Speakers
Sounds
Good day!
Please check the cord of the speaker if it is inserted at the right socket of your unit, or was the audio driver was installed? check if you see a speaker icon at the task bar. If you see an icon (speaker) maybe the speaker was not activated, double click that speaker icon, then, see if the volume was check, or other options, if none click options, properties, try other options by checking the box.
Thanks hope can solve your problem.
Oct 28, 2008 | Dell A215 Computer Speakers
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
