Question about Philips PA1036 Keyboard
Connected one time and now it won't connect at all.
Ds won't connect to wifi nintendo24 won't for the wii won't connect to the wifi
you need to get wifi at your house before you can use the wifi on the ds
Mar 24, 2013 | Video Game Consoles & Games
Fuel pump cycling long time bike won't fire,has good spark.
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
What to do When Your Motorcycle Won Start
1098 won start
Ducati 907 906 Paso Workshop Service Repair Manual 1988 1993 Searchable...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 14, 2013 | Ducati Motorcycles
Connection problem on vigo tablet
Not a solution, but... we could not connect to Vodafone, as the Vigo was not compatable with our Vodafone supplied Huawai modem!!!!!
Dec 27, 2012 | Tablets & eReaders
My Dell Dimension 4600 won't connect to the internet and has a solid orange internet light, help?
go into internet options and connections and tell it to never dial a connection see if that helps
Jul 12, 2012 | Dell Dimension 4600 PC Desktop
Tv won't connect with wireless
what kind of error message are you getting, if none open event viewer by hitting the windows key and the R key at the same time and type "eventvwr" after it loads look at your system logs to see if you have any messages there as to why it won't connect.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 20, 2012 | Computers & Internet
Serger won't chain off a stitch. Stitches won't chain and hold to fabric. Added new needle, rethreaded whole machine. Stitches won't connect to fabric or make a chain.
is it possible that the needles are in backwards?
it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
Apr 02, 2012 | Sewing Machines
Have a 1999 S10 Chev Truck had new cables on battery change just in new fuel pump. It has been doing this off and on for a few years but it's gotten so bad it won't start and had to be towed. It...
You have a bad typical connection hence the code, you are mainy going to have to troubleshoot this one on you own Chevy are popular for good looking wire connection and poor contact especially on the coil area just wiggle the connection and have some one crank it and it will start then wiggle it again and it will stall out, 1351 here is the definition Ignition coil high circuit input what this means is your are internaly disconnected you will need a terminal repair on the ignition coil this is a typical failure on the connection
Jul 11, 2011 | Chevrolet S 10 Cars & Trucks
My Wii will not conncet to netflix. It keeps telling me to try later and I tested to see if it still had internet connection and it does but it still won't connect to netflix. How do I fix this?
Netflix is down at the moment. my PS3 won't connect right now either. On the plus side, the last time this happened, they offered me a discount. =)
May 10, 2011 | Nintendo Wii Console
Netgear wna 3100 won't install on my windows xp. I have uninstalled it 3 times. It won't recognize the adapter. Then it does. Then in the end it won't recognize it even though it's there...
My adapter constantly loses connection completely to the router and cannont be re connected unless i unplug and replug back in the USB port. What a joke!?
May 06, 2011 | NetGear WirelessN 300 USB Adapter WNA3100
Philips PA1036 Keyboard Logo
21 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
