Question about Maytag MEW5530D Electric Single Oven
Oven will not get hotter then 255 degrees - Maytag MEW5530D Electric Single Oven
    Sergeant:
  • 222 Answers
Check your ignitor a bad ignitor will not draw enough amps to open gas valve correctly
Posted on Oct 08, 2009
Oven runs much hotter than set temperature. Usually 50 degrees hotter than what it is set at, but can go over 100 degrees higher.
Sounds like you need a new oven thermostat or get an oven thermometer and by experimentation draw up a new heating range for the oven dial.
Feb 11, 2011 | Frigidaire Ovens
My oven won't heat above 255 degrees. just curious what the problem might be.
You do not state if this is in centigrade or fahrenheit.
If it is centigrade, then it will not reach more than this if it is a domestic oven, if fahrenheit, then it should get hotter, so I would suspect a faulty oven thermostat as being the cause of the problem
Jan 05, 2011 | Ovens
Inconsistant oven temperature
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 25, 2010 | Ovens
Are gas oven does not get any hotter than 250 degreese c
that temperature is almost 500 degrees f. how much hotter do you need it to get??
what other problems are you having?
Jan 12, 2010 | Maytag CWG3100A Gas Single Oven
When using the oven setting it justs get hotter and hotter.
tt sounds like the thermostat sensor
Dec 27, 2009 | Ovens
My oven temperature is 100 degrees hotter than it should be
It will be the sensor inside the oven compartment that is causing the problem.
A new sensor should cure the prob, certainley cheaoer than buying a new oven.
Hope my advice helps you.
Dec 15, 2009 | Kenmore Ovens
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
Sep 16, 2009 | Ovens
Oven temp gets hotter than control indicates.
Alot of the thermostats are adjustable and can be recalibrated but when they act like this, it is best to replace them. It is just a matter of time before it quit all together. Electronic units are some what different.
Let me know what you do and I'll give you a hand in getting it going.
May 09, 2009 | Ovens
Creda oven
you might have already thought of this, buy an oven thermometer you can pop in the oven.
I bought one from my local cook shop
I have a the same cooker and similar problem - mine gets hotter by 50 degrees so I set the temperature 50 degrees lower than needed.
I noticed the problem a few years a go and luckily hasn't got any worse.
maria
Jan 02, 2008 | Ovens
Maytag MEW5530D Electric Single Oven Logo
83 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Mack Baxter
ashburton
Are you a Maytag Oven Expert? Answer questions, earn points and help others
