Question about Whirlpool Washing Machines
When I turn it on no water comes out but the spin cycle work?
    Sergeant:
  • 222 Answers
Make sure water is turned on
check for kinked hoses
if water comes out of the hoses when they are not connected to the machine then you have water if it does not enter the machine check water valve connections at the screen inlet and check electrical connections to the water valve if all is good replace water valve
Posted on Oct 08, 2009
Spin cycle on washing machine not working
The spin cycle relies on the sensors turning on the sump pump to pump out the water and a solenoid valve to open to allow the water to drain. They are both controlled by a water sensor located in the bottom of the machine. If it does not sense the water it will not let the pump start or the drain valve open. Check it out.
Jan 12, 2013 | Washing Machines
Set dial and water overflows, doesn't stop sending water in tub, No spin cycle
The water level sensor is faulty and so it does not switch even with water level coming to the set level. Unless the water level switch is triggered the water inflow will not stop because the inlet valve will not cut off.Remove the water level sensor and check if the diaphragm is working , if not it must be replaced.
Mar 13, 2012 | Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
My kenmore won't pump out the water. what could
couple of possible reasons and this will vary by brand of machine...lid switch could be bad...some machines will wash or agitate with lid up but will not spin unless lid is closed..others will not do nothing with lid up....some brands will not spin if the water level switch can detect water in the tub...this means your machine didnt pump the water out of the machine so it could spin couple of reasons for this 1 bad pump or bad pump motor(some machines have a pump that is driven by a drifferent motor than the one that drives the transmission)usually these machines use the water level switch to activate(turn on/off) the pump when the machine goes into spin cycle... some machines the pump wil come on and stay on for the entire spin cycle...some machines the belt will be bad and you just need a new belt....first thing to do is see if raising the lid will turn the machine off when it is in wash cycle if it does not..then it will in spin cycle..if the machine will not work in spin cycle the lid switch will be the reason why..
Sep 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
The wash cycle doesn't work, but spin cycle works!
Did you ever find out what was wrong with your washer?
Mar 23, 2009 | Whirlpool Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer will not do a spin cycle for rinse or end of cycle
you can check two things,. One is, is the belt broken or stretched, the other is the motor, is the motor turning if the motor is turning then replace the belt. If the motor is not turning replace the motor.
Feb 08, 2009 | Kenmore 44102 Front Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
