Question about Whirlpool MH3184XP Microwave Oven
Whirlpool MH3184xp microwave...no power, where is the fuse? I was changing one of the bulbs under the unit where the glass seperated from the base and shorted out the entire unit. checked the house breaker, not the problem...
  • Whirlpool Master
  • 9,047 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
In rare cases, it may just be a blown fuse. There are 2 or 3 in this model.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your model number).
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 11, 2009
While changing the light bulb under the unit, the wire connected to the light bulb holder touched the metal housing and totally blew out the microwave so it doesn't work.
normally there is a glass fuse in the circuit where the power comes in
check that fuse/ replace if necessary
As silly as it sounds --turn the equipment of at the wall before you work on it as it might have been you that blew and not the fuse
Jan 16, 2016 | GE Adora DVM1850 Microwave Oven
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
Is there a design change for the 20amp[4amp ceramic minifuse in- line holder] to just using a regular 20 amp 250 volt fusetron?
You can use a regular glass fuse as long as it's rated the same and fits the holder. Microwave ovens use a ceramic fuse to prevent the possibility of little pieces of glass under the cover if the fuse should break. But other than the body the fuses are the same.
Apr 19, 2011 | Whirlpool MH3184XP Microwave Oven
Just quit working. No power. Unit is getting power but does not work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 27, 2010 | Whirlpool MH3184XP Microwave Oven
Why did my maytag microwave oven power go out completely?
1 your inline fuse blew
2your magnetron t-stat poped
3 bad voltage from outlet
test the outlet with a lamp, if that works it can only be the other two
open the door, take the screww off the control panel
and the vent cover, two screws on top
behind the control and vent you will see the mag t-stat, it should read continuity, and the inline fuse should be right above it a small glass tube fuse like a car
Oct 16, 2009 | Whirlpool MH3184XP Microwave Oven
Whirlpool microwave model #MH1140XMQ-1. I needed to change the light bulb on the bottom of the microwave that shines on the stove below. I started to turn the light bulb and the bulb seperated from the...
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Or if you prefer, you can order a new control circuit board for it here for $140.10 plus shipping. (Just enter the model number as MH1140XMQ-1 without the dash).
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Jul 04, 2009 | Whirlpool MH7140XF Microwave Oven
Nothing working - just quit. Power source ok.
There are 3 fuses in that microwave. I had a similar issue. The one that I had to replace was the little ceramic fuse that is in line after the big fuse which is connected to the main line.
I couldn't find the ceramic fuse but I replaced it was a glass one about a year ago and it has been working since then. The fuse if located on the right front panel.
Dec 29, 2008 | Whirlpool MH3184XP Microwave Oven
Whirlpool microwavewave hood comination mh3184xp
My Whirlpool MH3184xps is shooting a spark when in use with the rack. When the rack is removed the oven works fine. I am guessing that some of the coating on the rack has cracked and peeled and is exposing some aluminum. Has anyone else had this problem?
Feb 04, 2008 | Whirlpool MH3184XP Microwave Oven
Replaced light bulbs, lights still don't work
there is no fuse power comes staight from the transformer on the board. the only possible fuse is the main fuse that will kill all the power
Nov 01, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
Whirlpool MH3184XP-B 2 Black- Will not start, no power, no display
Downstream of the main 20 amp breaker in the upper right hand corner, is a miniture 4 amp fuse in an inline fuseholder. I replaced this and so far, so good
Aug 21, 2007 | Whirlpool MH3184XP Microwave Oven
Whirlpool MH3184XP Microwave Oven Logo
860 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
