Question about Tally Serial Matrix T2155 Printer
BOOT displayed on LCD display
On the LCD display it says BOOT and nothing works from then on. I turned the power off and on with the same result. None of the buttons do anything.
    Novelist:
  • 169 Answers
The 'Boot' message indicates the printer has switched to the firmware download mode as it has not been able to load the firmware.
This can happen because the firmware has become corrupt, in this case you can reload the firmware and the printer will be back working.
This problem can also be seen if flash memory has become damaged, this will not be recovered by reloading the firmware, the logic board will need to be replaced i you are unable to rectify the problem by reloading the firmware.
The firmware for the T2155 can be found on the Dascom website at;
http://www.dascom.co.uk/firmware/serial-matrix/188-t2155.html
Posted on Nov 07, 2009
The Onkyo DV-CP706 changer doesn't seem to complete its boot-up whenever turned on. The console display says "OnkyO DvD" and nothing else. The monitor display indicates "No Disc"...
Hello, I am sorry about you issue. It sounds like your player needs to be serviced. I have included a link to search for an authorized service center. Thank you, Onkyo USA
https://www.onkyousa.com/Support/servicecenterlocator.php
Jun 15, 2017 | Onkyo DV-CP706 Multi-disc DVD Player
I found a small part (looks like the top part of a pen) in my washer, now when i turn on the washer the goes in but does not stop, does not start the wash cycle. Also door keeps locking and unlocking.
How to run a diagnostic test:
  1. Unplug power cord, then wait 30 seconds.
  2. After plugging in, follow these instructions...
To Enter SERVICE MODE: Press Signal-Delay-5ignal-Delay (within 30 seconds of plugging in washer).
To Exit SERVICE MODE: Repeat Signal-Delay-Signal-Delay.
Here are the possible tests to run (TEST LIST). The error codes from t02 will probably be the best indicator of your problem. (scroll down to bottom to see what each command button does once you are in test mode)
  • "t01"
    Model ID
    Verifies (or sets on new board) the proper Model id
  • "t02"
    Error Codes
    Lists up to 10 control-detected problems
  • "t03"
    Software ID
    Verifies using latest Control-eePROM-lnverter software
  • "t04"
    Exercise lCD/lEDs
    Verifies that all the displays and buttons work
  • "tOS"
    Pump Test
    Tests drain-out pump
  • "t06"
    Pressure Switch Test
    Fills to all 3 levels, then pumps out water
  • "tOT'
    ThermistorlHeater Test
    Verifies that both the Thermistor and Heater work
  • "t10"
    Tumble Test
    Verifies Washer Tumbles (I.e. Wash cycle)
  • "t11"
    Spin Test
    Verifies Washer spins
  • "t12"
    Dispenser Test
    Verifies Dispenser fill works-for all four fill modes
  • "t13"
    EOl Test
    Performs End-of-Line test sequence
Button Commands (based upon test mode)
t01 prerequisites: none
Start Displays defined Model id (01-04); displays "---" if new board (to set Model id, rotate knob unlil desired id [01-04] displayed, press and hold "START' key to program desired model)
Power Returns to "t01"
t02 prerequisites: none
Start Displays most recent error code (EOO=none)
Start Displays previous error code (up to previous 10)
Hold start Clear all error codes (and then displays EOO)
Power Returns to "102"
t03 prerequisites: none
Start Alternate "cod" and Control Software version
Start Alternate "EE" and eePROM version
Start Alternale "Inv" and Inverter Software version
Power Returns to "103"
t04 prerequisites: none
Start loops on lighting lED's, LCD and cycle ids
Any button Beeps when depressed
Power Returns to "t04"
tOS prerequisites: none
Start Displays "P" and pump for 60 seconds
Power Returns to "t05"
t06 prerequisites: none
Start Displays "E" (for Empty) and starts filling when reaches Foam level-displays "F"
Start Fill, when reaches Main level-displays "nl"
Start Fill, when reaches overflow leve~ displays "OF," pumps out, displays "E" when tub empty
Power Returns to "t06"
t07 prerequisites: Main level pressure switch must work
Start Displays temperature in OF, fills to main level, turns on heater up to 5 minutes, displaying rising temperature
Power Pumps out water and returns to ''t07''
t10 prerequisites: none
Start Displays "It" and tumbles tub alternating the direction every 5 seconds
Power Stops tumbling and returns to "t10"
t11 prerequisites: none
Start Spins to 400 RPM displaying increasing RPM
Start Spins to 1100 RPM [Greater than or equal to 1000, displays "Axx"; Greater than or equal to 1100, displays "bxx" (xx, 0 to 99)] [currently error-automatically goes to 0 RPM]
Power Stops spinning and returns to "t11" when stops
t12 prerequisites: none
Start Displays "pdt" and fills via pre-wash chamber
Start Displays "ddt" and fills via main wash chamber
Start Displays "bdl" and fills via bleach chamber
Start Displays "Fdt" and fills via fabric softener chamber (stops if reaches Main level during any fill)
Power Pumps out water and returns to "t12"
t13 prerequisites: none
Start Starts EOl test sequence (NOT used in Repair)
Power Returns to ''t13''
Once you have the diagnostic codes, check this post for the meaning of the codes:
http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
Jun 25, 2011 | General Electric WCVH6800J Front Load...
I push the power button and the light on the button comes on and I can hear something spinning but the laptop won't boot up
have anything in display? if there is none, it is an LCD Panel problem and system board problem. If there is display, just open the back part of the laptop and remove the RAM modules and turn it ON. the system should beep. Then turn it OFF and after 1 minute put the RAM modules back and turn the laptop ON. should get the display now
Aug 30, 2009 | Acer Aspire 1800 Notebook
My son bought an AOC LCD TV (model L24H898) last month and connected his laptop and XBOX to it. Yesterday we lost internet connection and the screen on the TV went blank. Now none of the button on the TV...
According to the manufacturer, to reset the entire unit do the following:
1. Press and hold "Menu" and "Channel +" on the TV. 2. Using other hand, press the power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and select. 5. Power off and re-boot the computer 6. Run channel auto-scan to regain the picture.
Aug 28, 2009 | AOC L24H898 24 in. LCD TV
Garbage video on display on boot up
Sounds like your notebook video card is bad. It drives both the LCD panel and external displays. You'll need to replace it.
Mar 03, 2009 | Toshiba Qosmio G35-AV650 Notebook
Sony Ericsson w580i LCD replacement issue
ok. The most probable problem is that the display is loose. heres what u should do. First, slide the phone open and open the top cover of the phone by first removing the top right corner first. Now, carefully remove the display by lifting the bottom of the display first and pulling it out. now, using sticky tape, stick the end of the circuit comin out of the display to the socket in the phone. Be sure to match it properly. now, carefully insert the display back by sliding the top part in and then clickin the bottom into place. Replace the cover and turn the phone on;. If this doesnt work then u hav to dhange ur display.
Sep 26, 2008 | Sony Ericsson w580i Cellular Phone
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
BenQ FP7IB LCD monitor, turn black aftr BenQ logo
Try to plug into another computer and wait to see.
If it turn up to be same it somewhere defect from the main board of the lcd.
If if not the same turn up to be, you should reinstall the OS because the software is corrupted or your display card problem.
Apr 16, 2008 | MPC Computers AOC 7F 17" CRT Monitor
Tally Serial Matrix T2155 Printer Logo
169 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
