Question about Nintendo DSi Black Console
Yesterday, the screen was working, today the top screen started playing up. The left side is a textured black, while the right side flickers the menu screen randomly. The middle either has a yellow or pink line going through it. My friend beleives it has something to do with the ribbon cable. What do I do to fix this?
    Scholar:
  • 64 Answers
Your friend is right, you have damaged the ribbon to the top screen, you can buy them from the internet with the screen, and you can buy the tools also to unscrew the case, if you dont think you can do that, their are also places you can sent it to get it fixed, look on the internet.
Posted on Dec 25, 2009
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
I have no idea how to set the time for my clock on my kdc mp335 cd player
i was in a similar situation today luckily i was able to figure out the solution
follow this
1.switch to STANDBY MODE using the power button on the remote or using the SRC button on the player itself
2.Once you are in the standby mode , press the MENU button ( bass button ) on the left hand side top corner for 1 second
3.Use the right control Knob up and down to switch to CLK ADJ mode .
4.Once you are in CLK ADJ mode Hold the right control Knob for a second until the time starts flickering for change
5.Use the right control knob to change the settings , up and down changes the hour and , left and right changes the minutes
6.Press the MENU button ( bass button ) to save and exit
7.ALWAYS MAKE SURE YOU ARE IN STANDBY MODE
hope this helps :)
Aug 20, 2011 | Kenwood KDC-MP335 CD Player
ViewSonic VP171b resolution problem
If you went from a standard screen to a wide-screen, you have to upgrade the video card.
Also, try going into the menu option on screen and have it automatically detect settings.
First thing you should do is update your drivers.
Should have said that first.
Jun 12, 2009 | ViewSonic VP191b 19" LCD Monitor
My Asus eee PC fails to boot
Reboot the system
Press F8 at boot startup. In the boot menu
Choose Last Known Good Configuration. If this doesn't work
Try Safe Mode
Go to Device Manager
Roll Back any new driver you've installed
and/or
Go to Add/Remove programs
Unistall any new software you've installed
Mar 31, 2009 | ASUS Eee PC 701 Notebook
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Jan 21, 2009 | HP W2007 LCD Monitor
Laptop display is split both horizontally and vertically in WinXP
the last one i had with this prob had an ati radeon xpress 200m video card and it was defective had to replace it.
Dec 05, 2008 | Toshiba Satellite M30 Notebook
Creative Zen V mp3 player's screen
try putting it in recovery mode what you have 2 do is is hold down the play button while you turn on your mp3, as soon as you see thee logo release the play button and then choose the "reload os/ firmware" then follow instructions
Mar 27, 2008 | Creative Labs ZEN V Plus MP3 Player
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Nintendo DSi Black Console Logo
71 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
