Question about Toshiba TLP-710, TLP-711, TLP-G5, TLP-G7 Projector Lamp - TLP-L3 Projector Lamp
My toshiba tlp710 projector wont power on - Toshiba TLP-710, TLP-711, TLP-G5, TLP-G7 Projector Lamp - TLP-L3 Projector Lamp
  • 70 Answers
Check your power cord first, if good, if not replace it. if the problem still occur, check the power supply board of your projector. and replce it.
jahting
Posted on Oct 08, 2009
Toshiba TLP s30 projector identification part
http://www.nextag.com/toshiba-tlp-s30/search-html
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
Toshiba projector amber light keeps blinking and lamp does not come on.
it seems like it is overheated. make sure nothing is blocking the fans. even if the fans aren't covered, it seems like it was over heated in the past. if it wont turn on even when the vents aren't covered, the device is permanently damaged and can only be fixed by opening up the projector.
Jan 26, 2011 | Toshiba TLP-701U Data Projector ( TLP701U,...
I cant get the message lamp life is ending off
Unplug your projector from the power source. Hold down the On/Standby button and the Menu buttons at the same time and plug the power back in as you are holding them down. This will reset the lamp hours used and should remove that message.
May 30, 2010 | Toshiba TDP-S8 Multimedia Projector
I just replaced my bulb on the toshiba tdp t45u projector and the red lamp light is still on and the projector still wont come on? how do i fix?
Check out the Power supply to the lamp . It must not be high . . Check if the voltages are correct to the lamp's unit and it's PCB [printed circuit board]. I recommend using a service manual .
Here is how to replace a projector's bulb correctly :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
I hope this will help .
Apr 11, 2010 | Toshiba TDP-PX10U DLP Projector
I have a Toshiba TDP ET20 projector, the problem is that there is that it wont power up. There is a click when the power is turned on but no lights, including the main projector light, come on
if the fans come on but no lights, listen for a high-pitched whir. if you don't hear it, the colorwheel needs to be replaced. if you do hear it, replace the ballast. if no fans, replace the power supply.
Nov 06, 2009 | Toshiba TDP-ET20 DLP Projector
Having the yellow flashing light
Sounds like maybe a power surge killed the TV. If it is newer, try contacting the Manufacturer for warranty repairs.
Apr 16, 2009 | Toshiba TDP-ET20U DLP Projector
In focus dlp 420
Hi Barron
Yes there is , you can try holding down the Menu & Power buttons for a couple of seconds.
Feb 28, 2008 | Toshiba TDP S3 Multimedia Projector
225 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
