Question about Garmin StreetPilot c340 GPS Receiver
I cant unlock my garmin nuvi 200.
I dont know the code,as it was given to me with no code to unlock it.
  • 4 Answers
If you bought a locked satnav without a code you are either very stupid or handling stolen goods. And dont give the **** that you didnt realise or didnt check. No-one in their right minds buys a satnav without seeing it working.
If you still claim its legit then send it off to Garmin and they offer an unlocking service
Posted on Oct 13, 2009
My garmin nubi 200 gps is locked
Take the unit to the location at which you first entered the PIN. The unit will unlock and you can reset the PIN to something you can remember.
Jul 09, 2010 | Garmin nuvi 200W GPS Receiver
NuviĀ® 255W Car GPS Receiver: i have a garmin nuvi 255w and its locked and need ...
I had for 2 years a nuvi 255w and its as working real good. Until one day i tried to open it up and it ask me a code pin. Witch i dont have. Ive been the only one owner on that GPS and never put any pin code on it and now just like that it want one... Grrrr that **** me off i cant use it anymore i dont have any acess anywhere exept that pin code of 4 number,. Is this possibility of update? I dont know I am the only one in that situation?
May 16, 2010 | Garmin nuvi 255W GPS Receiver
Hellio, my garmin nuvi 200 cant find a satellite,
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Mar 24, 2010 | Garmin nuvi 200W GPS Receiver
Forgotten Garmin 200 password
I've been trawling for unanswered questions; this information may be too late for you (or perhaps it may help you resurrect a useless machine which you have put away) but it will certainly help others searching for advice with the same problem.
You have Garmin Lock activated on your nuvi: there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it or you wouldn't be reading this).
2. Take the unit to the Security Location you chose when activating Garmin Lock: it will then unlock without the PIN code and you can then either reset the PIN or disable Garmin Lock. The Security Location should not be the owner's home address, but many owners ignore this recommendation. Many owners choose their workplace or a close friend or relatives address for this purpose.
If neither option works then your unit is useless unless you send it to Garmin with proof of purchase. Garmin charge for the service and if your maps are not up to date then it's really a waste of money as the investment would be better spent on a new unit with current mapping.
I hope that you manage to either fix your problem using my advice or at least can decide whether to abandon the unit and buy another.
Feb 20, 2010 | Garmin nuvi 200W GPS Receiver
My Garmin Nuvi 200 has a message that says No detailed maps found that support routing. The nuvi cannot be used without them. I just used this garmin a few hours ago, and it was fine. Now I can't get...
You need to call garmin to have them help you unlock your unit. It sometimes requires the 25 digit unlock code which they have on hand. 1-800-800-1020 I believe.
Aug 15, 2009 | Garmin nuvi 200 Car GPS Receiver
Garmin nuvi 200
Jun 08, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
GARMIN 200 LOCKED
how do i get a passcode a for a garmin nuvi 200 if its lockd and u forgot the code and u cant send it back to da company
Jul 13, 2008 | Garmin StreetPilot 2720 GPS Receiver
Nuvi 200 unlock code
I know how to fix it first send me an email to g.luis_54@yahoo.com
then take the file that i send you and save it to the desktop
hook up your garmin to the computer
and open the start thing
find computer then open it...
find garmin
then open the other garmin folder inside it
drag the file that you saved on your desktop to the garmin folder
close it
then unplug the unit....
and presto you are finished....
May 11, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200
how unlock garmin 2000
Dec 30, 2007 | Garmin nuvi 200W GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
127 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
