Question about Saws
Saw has lost cutting power
New scraping noise when I turn on the saw, and the blade slows down and stops when I begin cutting wood. Seems like some kind of clutch failure.
  • 1 more comment
  • hwhooperjr Oct 08, 2009
    Blade path is clear and the tension seems OK. Motor sound is normal, it does not slow, and the belt tension seems normal. The motor and belt continue to spin even though the blade slows to a stop. With the motor off, the drums and blade turn easily. The problem seems to be in the shaft that connects the pulley to the bottom drum. I assume there is some type of clutch in the housing, and that is where the scraping sound is coming from.
    Thanks. I'll let you know how it turns out.
  • hwhooperjr Oct 17, 2009
    Just a follow-up.
    Finally turned the saw over today, and the pin holding the pulley to the drive wheel shaft was gone. The set screw had backed out allowing the pin to slip out. After sifting through a couple of inches of sawdust, I was able to recover the pin and tightened the pulley back in place.
    Running like a top!
    Thanks for the insight.
    Brigadier General:
  • 4,088 Answers
Open the side cover and inspect the blade path and blade tension. Rotate the blade by hand looking for interference at any point. Make sure the drive pulley is not slipping on the shaft and that the belt is not loose or badly worn. Make sure the two large drums that carry the blade turn easily (dry bearing?). Does the motor slow down? Are the drum rim surfaces (rubber) in good shape? If the tension device is at limit, but not tightening the blade, the blade may be too long.
Posted on Oct 08, 2009
  • drallim Oct 08, 2009
    Band saws don't use any kind of clutch that I'm aware of. Look for a loose mounting of the drive shaft to the lower drum--maybe a sheared key between the shaft and drum. Remove the blade and enough housing to get at the lower drive. I'm sure that the answer will be apparent when you get that far into it. If you can't buy parts for it, you may need to seek the services of a machine shop to repair a damaged shaft or drum center. It could be as simple as tightening a clamp nut. Good luck!
  • drallim Oct 18, 2009
    A strong magnet would have helped with the last process. It's good to see people try to repair their own things than to just chuck it in the trash and buy another. Be sure to tighten the set screws on the motor and the saw drive pulley. Thanks for the feedback!
I have installed a new blade in my circular saw R32021 and the blade stalls even before I begin to cut wood
by stalling do you mean that the blade stops spinning or the motor stops turning
if the blade stops spinning then the mounting bolt for the blade is not tight enough
if the motor stops spinning , junk it and get a new unit
Jan 20, 2017 | Blade Saws
Slows down and stops when trying to cut hardwood
You just do not have a saw that has enough power, the blade is dull or both. Change your blade and push the wood through slower or get a more powerful saw for the hard woods.
May 11, 2016 | Delta Saws
Dose not cut in a straight line wonders
First question: What are you cutting? Are you cutting wood? If you're using fence, I need you to make adjustments on it . The nature of the band saw is to drift either left or right being parallel with the band saw fence. Is the blade tension too tight or insufficient? Check your manual for correct tension or you can just see in the tension gauge on your saw. Please this blog on how to check the correct blade tension . What is your feed and speed rate? Make sure the you're not feeding the wood too slow or too fast. Are you using new blade? Your blade is may be dull or low quality. I purchased my blades on www.sawblade.com . Their Haltbar 201 Series works great on general wood cutting.
Last question, have you taken up time to tune up your saw? See this blog for your reference.
Sep 11, 2013 | Craftsman Saws
Saw stops when i start cutting 1/2 plywood.
If it actually binds and stops the motor...... it sounds like the motor is bad, the bearings are bad, or the blade is on backwards. If the motor keeps spinning, but the blade stops then the gears are bad or the blade bolt is not tight.
Dec 10, 2012 | Worx Versacut Mini Circular Saw
I bought a ls1016 coupond mitre saw this week. I was cutting cedar 2x6 's today and had a few kick backs. I am building my deck and do not feel safe using the saw after the kick backs. Why as this...
Sounds as if the blade is dull. Or perhaps bent. A dull or bent blade blade will 'grab' the wood, rather than cut it, resulting in binding, or kickbacks.
Solution; replace the blade with a fine-toothed, good quality blade. If the blade is new, then check that the blade is bolted tight on the arbor. If the blade is loose, it can result in kickbacks.
Also, check that all the bolts/fasteners/locking mechanisms on the saw are tight, and in good working order. Sometimes a tool new out-of-the-box will have loose screws/nuts/bolts that need to be tightened up.
Also, when cutting, use a smooth, slow, motion, being sure to give the saw the time it needs to make the cut.
Jun 19, 2011 | Makita LS1016LX 10inch DualSlide Miter Saw...
I'm a wife with a do-it-yourself knack. I recently purchased a Ryobi 10 in. BTS211 table saw. I find the manual complicated as far as how to actually use the device. Can you recommend where I can get...
I am a retired contractor.
I have a shop with a 10" table saw.
And I have opinions about safe operation.
For safety, turn saw off when making adjustments.
1) Raise blade:
There is a handle you turn to raise the blade.
If you are cutting 1/2" plywood, then set your blade at 3/4" or a bit more.
Keep blade low and away from hands.
Keep hands high and away from blade.
For 1-1/2" thick 2x4, I usually set the saw at 1" and run the board through, and then flip the board over and run it through again, taking 2 passes to make really thick cuts.
2) Blade angle
There is a second handle you turn to set blade at an angle up to 45 degrees
Angle cannot be set if saw blade is fully raised >> lower blade to half way or less and experiment.
Angle cuts are difficult if wood is not perfectly flat and square, or too long or too short (boy is that helpful ... but cutting angles takes some experimentation)
3) Table Guide
You stand behind power saw to operate
The saw table guide is on left side of blade and clamps across the table
The guide markings show inches >>> these are usually approximate
To set guide for accuracy, measure distance from blade to saw guide, and then clamp guide down.
4) Push sticks push sticks push sticks and other safety stuff
Let me emphasize safety first last and always
A table saw will chop your fingers off in a blink
On the plus side, I hear it doesn't hurt. But OMG.
There is a very strong human instinct to reach in with your hand when working on stuff
Train your mind >> if the saw is running, do not lean or reach into the saw
If a board is stuck >>> turn off the saw and wait for full stop
If you wear baggy clothes of a loose shirt, the saw will grab you and pull you in too fast for you to react
Keep your clothes tight and your arms bare
Always use push sticks or push boards::
Notice the saw blade is set low
Two push sticks are used to assist when cutting short board > one stick holds down the board ahead of blade, the other stick is pushing board through saw.
Keep your hands away from the blade no matter what.
The person stands behind and to the side of the board being cut.
The cut wood is supported by a catch table (in this case there are rollers)
Where to stand
Obviously you stand behind the saw to cut wood, and sometimes with long pieces, you can move in front and pull them through, and sometimes with large plywood you stand kinda back and to the side.
Why not stand directly behind a saw? Because saws throw stuff back.
When 'ripping' a board lengthwise as shown in photo above, if the saw catches the board just right, it will throw it backwards like a spear.
If a board 'binds' the saw causing saw blade to stop, then turn off saw, back up the board, and cut again.
Crosscut guide
The saw comes with a T-shaped guide that fits into a groove.
This is a 'push stick' >>> you use it to cross cut a board, and it lets you stand to the side of the saw blade so things wont flip back on you
When using the cross cut guide, remove the table guide that clamps across the saw, or push the table guide WAY back so pieces don't get caught in a bind and the blade flips up the piece and hits you in the face
Remember, the saw throws everything backwards
The saw is strong and fast, and you are best when traveling slow and without rush around your strong friend.
Oct 15, 2010 | Garden
When cutting wood with band saw saw will cease up
This could have many causes...depending on the model of saw, the wood being cut, the blade you're using, etc. etc.
Check that the blade is correctly installed, up to tension, and sharp. Make sure the wheels run smoothly on their on, and under power. Check the horsepower of the motor, and make sure to keep the feed rate down within the motor's capacity. Finally, don't twist the work being cut to a smaller radius than the size blade will handle, or you will bind the blade in the cut.
If you are cutting wood with pitch or grain that is likely to be under tension, perhaps you need to insert a wedge into the cut to prevent the work from pinching the blade as it continues the cut.
I hope that leads to a solution. Sometimes all you can do is feed slowly and be patient...
Jan 25, 2010 | Saws
Cutting stair stringers with circular saw
the start of the cut is starting to close up and pinch the back of the blade once you have gone past centre,if the blade is past the starting edge you can tap a small wedge into the start of the cut and that will stop it .I AM AN EXP SAW PERSON TO PROVE IT I ONLY HAVE A THUMB, AND ONE REATTATCHED FINGER ON ONE HAND .that happened on a bench saw only the back of the saw blade lifts the wood and for some reason i pushed it back down,DUMB ..Be careful and think before you do , But a wedge will solve your problem
Aug 19, 2009 | Saws
Grinder question
Use a pencil and straight edge to mark the cutting line on the wood. Place the wood on the saw table and line the mark up with the saw. Place the mark on the right side of the blade to ensure proper cutting. Plug the saw in and put on your safety goggles. Support the wood on the work surface with your left hand, placing it far from the saw blade. Place your right hand on the handle, and push the trigger to start the saw. Move the saw blade down onto the wood. Put constant pressure on the handle to slowly move the blade through the wood. Release the trigger and raise the blade once the cut is complete. Make diagonal cuts in the same manner, by marking the wood and lining the mark up just to the right of the saw blade. Continue as you would for a straight cut. Remove the wood from the saw. Unplug the chop saw and dust the sawdust off. Remove the dust bag from the back and empty it. Vacuum any remaining dust off of the saw.
Aug 27, 2008 | Dremel 10 Diamond Cut-Off Wheels Saw Disc...
Saws Logo
136 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
