Question about Kenmore Dishwashers
Top spray arm in dishwasher will not spray
Top sray arm in dishwasher will not spray
    Sergeant:
  • 222 Answers
Poor water pressure due to a clogged flowplate assy if the flowplate assy is not clogged with gook and hard water then you may need a new motor, a weak motor may not push the water well enough to get up to the top
first check entire flow are impeller etc
Posted on Oct 08, 2009
Why is the upper sray arm is not working in kitchenaid model KUDR01TJ
There are 2 spray arms for the top rack. A small one on the dishwasher top and a bigger one attached to the bottom of the upper rack. Both get water feed from a flat tube that runs up the back wall of the dishwasher. Not much to the very top little arm--just check the spray holes for any food blockage and try to clean with a brush or tooth pick. The bigger arm on the bottom of the top rack gets its water feed through a hole about half way up the flat tube on the back wall. When you push the rack all the way in, it has to plug itself into that hole in the back wall. Check that plug in area and make sure nothing broke off that would keep it from making a good seal with the rack all the way in. All check all the holes in the spray arm for food blockages. On the very end of all spray arms is a main hole that is the drive hole to spin the spray arm. The water shoots out that hole and acts like a jet engine to push the arm around. Make sure those holes are clear.
Mar 24, 2015 | KitchenAid Dishwashers
Top sray arm is not moving on my bosch Model #: SHE43P05UC dishwasher
Either the delivery pipe to the top spray arm is blocked or end of arm is split or the spray arm holes are blocked.Check for physical obstructions around the arm.I take it that the bottom arm is ok.The other problem could be a fault at the main wash pump.
Hope this helps.
Jun 07, 2010 | Dishwashers
Message -spray arm blocked
Check water pump inside the machine for its full speed.If the speed is low check the capcitor and replace.
May 27, 2010 | AEG 24 in. Favorit 80860iW Built-in...
7-8 year old KitchenAid washes dishes on bottom, but not on top
Position the spray arms in a certain position. Activate the dishwasher for a few seconds and then examine the position of the spray arms. If the upper spray arm has not moved, then either there is no water coming to the spray arm or the spray arm is clogged.
Apr 14, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Top rack not cleaning properly, not sure if top spay arm is working ?
Ensure that the spray arm is movable. Inspect the spray holes in the top spray arm. If clogged, clean the openings. If no clog, position the spray arm in a certain position (e.g.: arms facing front and back). Then activate the dishwasher for a minute or so and open the door to determine if the spray arm has moved. If not, there may be an issue with the water feeding to the spray arm (typically via the water pump, etc.).
Feb 19, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Bottom spray arm not turning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
rthd
Jun 09, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Top spray arm not connected to anything so dishes dont wash properly
as long as you have a spout mounted in the middle of the top basket, everything is fine , water will spray from top nozzel (mounted in ceiling of dishwasher) into spout entering spray arm.
May 01, 2009 | Dishwashers
Upper sray arm does not turn
Take the bottom spray arm off and take out the screen etc. When these are removed it will expose the volute cover. The volute cover is what the lower spray arm attaches to, there will be a few screws that hold it on, when the screws are removed it will lift off. Under it you will find a check ball, it should move freely, it is most likely stuck in place, if it is free it and clean it and the track it rolls in. re-assemble and it should work. hope this helps
Aug 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
No flow to top spray arm
the tube feeding the top spray arm may be clogged. The top srpay arm seal may be defective as well.
Mar 26, 2008 | Dishwashers
Dishwashers Logo
108 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
