FREE UP HARD DRIVE SPACE
I HAVE 3 GIGS OF MEMORY BUT MY COMPUTERS HARD DRIVE IS SHOWING ALMOST FULL, I ALSO HAVE A 750MB EXTERNAL HARD DRIVE I HAVE BEEN USING AS BACKUP , IT JUST IS NOT BACKING UP THE D DRIVE, IS THERE SOMETHING I AM DOING WRONG?
    Novelist:
  • 190 Answers
Hi! Your 3 Gigs of memory have nothing to do with your disk storage. You may try freeing some disk space by doing the following:
Clean up your recycling bin by selecting the Empty Recycle Bin option, after right clickin on the icon.
Clean up the All User's temp directory, usually within your Windows installation drive-> Windows folder, called TEMP folder.
Clean up your own TEMP folder, usually hidden and found within your own user name folder. To make this folder visible, in File Explorer, go to Folder Options, and find the entry that reads: Hide system files. Uncheck the option. Make sure you reset it after you're done.
A little riskier is to try to resize your virtual memory, or the amount of disk space that Vista (and other versions of Windows) uses to emulate physical RAM, when you have exhausted it.
You may also save disk space by sacrificing the Hibernation feature by disabling it. If you do this, by going to the Advanced Settings of Vista, under System, uncheck the box next to your drive, and while having Hide System Files also unchecked, you can physically delete the file, usually found at the root of your main drive (usually C:) Note: For this change to take effect, you will have to restart your system with a cold boot.
Try buying some software similar to Norton Utilities (a reduced of it is available in Norton 360) that will defragment your drive but will also clean up stray and orphan files left behind by improper uninstallation of other software and temp files left behind when an application like Word, or any other, crashes.
Posted on Oct 08, 2009
I connect my seagate external hardrive to my xbox to store some data on it because my xbox does not have an internal hardrive. So i figured i can use my portable external hardrive to my xbox, and it said i...
Either you have 50 gigs of stuff on there or your hard drive space is not being properly read. U might need to reformat the drive if necessary.
Meanwhile your xbox electronics may have a limit on the size of space - so if the drive has 200 gigs of space on it and your unit will only recognize 32 gigs, then that is all it sees and can use. Capiche?
Jun 16, 2017 | Seagate Computers & Internet
320gb seagate hard drive showing only 2gb
total space 2 gig or free space 2 gig?
go to my computer right click on drive and report back what the balance of the drive shows for each color
May 24, 2012 | Computers & Internet
I have a Fanner SPIRE Aluminium Gigapod External 3.5" external hard drive linked to my Windows XP laptop but the link up between the two has recently become increasingly slower as has the response of the...
The hard disk inside that Spire case has died - running the free space clean from CCleaner (a very intensive procedure) has been the death blow to an already sick disk.. Nothing more can be done to save it and the data on it. Replace it with a new one.
Jul 17, 2010 | Fanner SPIRE Aluminium GigaPod External...
Wd3200 shows 320 gig total space yet says it is full at 36gig?
i used MyBook 640gig but i didn't have a problem like yours,.. but maybe i can help with your problems, here is a tip to run Mybook properly, and i've seen a cause which the capacity of small even though you are expected and have more space on it... one thing is did you got spam by some kind of virus like trojans, worms, mostly this thing come up to used your availability of space, if theres is so remove it by using Trojan Remover,... with all due respect always update your antivirus everyday if you still use. so far this what i notice about this problem and i solve it with my mybook640gig.. good luck!
Jul 09, 2009 | Western Digital My Book Essential 320GB...
I can't delete files from my Maxtor 3200 external hard drive
The other comments are not the easiest way to free up space on the drive. The reason you aren't seeing a change in free space is because of a drive error (probably unplugged without unmounting). So First open up disk utilities and fix the hard drive (should only take 1-2 min). After the drive is fixed select erase free space (zero out data is fine for now). This usually takes about 20 min for me with a 120 gig hard drive. This allows you to have the free space without having to move all of those files around (which for me would be a problem because I have 100 gigs used on my drive, which would take forever).
Jun 20, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Memory loss
It seems to me that when the drive was partitioned, the whole thing was not partitioned. If using Windows XP you can go under the Control Panel, Administrative Tools, Computer Management and then Disk Management. You should be able to see the drive and if any unpartitioned space is available.
Sep 09, 2008 | Maxtor Hard Drive
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
PROBLEM WITH MY WWD EXTERNAL HARD DRIVE
It appears it is not being recognized and mounted. Try running the add new hardware wizard if it isn't in your device manager already.
Feb 12, 2008 | Maxtor OneTouch II external hard drive...
Moving files
just go to All programs<Accessories<System Tools<Backup. and choose the option you want.Once you have choosen what all you want to backup than you can choose the option for the place where you want to back it up.
Hope that works!
Dec 27, 2007 | Computers & Internet
Backup hard drive to an external hard drive
"what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs."
That error means that the FAT32 file system only allows 4GB files or smaller to be transfered. The chance that the backup file (.bkf) is larger than 4GB suggests that this file is causing your problems. You could try manually copying around that file (selecting all files from that folder except the large one) and see if that works.
Usually you will get many errors copying a drive directly as system files will be inaccessible and whatnot. Your best bet is to limit your copying to "C:\Program Files\" and "C:\Documents and Settings\", assuming you have Windows.
Dec 13, 2007 | IO Magic Corporation GigaBank (I250HD35)...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
