Question about Kenmore Elite 21086
I push the drywer start button and the dryer starts but will not stay on . I have check continuity of the col and thermal swicht on the heating elenmment and it is good
    Sergeant:
  • 222 Answers
Check the door switch and latch to be sure it is not coming open
Posted on Oct 08, 2009
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Dryer won't start when start button is pushed.
you might want to check the door switch , its possible when the door switch is open the unit will not start
Aug 04, 2011 | Whirlpool Inglis IP8200 Dryer
My dryer start when i push the start button
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Jun 11, 2011 | Estate Dryers
Won't start, stays in the sensing mode when i push start button.
I had the same problem & just had a repair man out. A Thermal Fuse was blown - this occurs if you run your dryer a lot & don't let the cycle complete so the dryer cools down. If you stop the dryer mid cycle it's important to leave the door open so it can cool down or run a timed dry cycle on Air Only so the dryer can cool off.
My repair took less than 30 minutes & you can get the Thermal Fuse (item #2986) on www.repairclinic.com - part is $13.05 + shipping. Shipping varies depending on how soon you want the part.
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
To test it, use an Ohm meter or continuity checker, if no continuity it must be replaced. Unfortunately, you can't tell if it's bad by looking at it.
Nov 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
Runs when PTS held but shuts off when released/no heat
No problem at all.The motor has a start and run winding.Your run winding is bad.The reason you have no heat is the run winding has to run to close the contacts on the motor switch.Replace the motor ,both problems solved. Hope this helps Please rate my response :)
Dec 13, 2009 | Kenmore Washing Machines
Dryer buzzes when start button is pushed but does not start
Check for a blown thermal fuse. It's about an inch long and is just inside the rear of the dryer and is usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a blown thermal fuse. Hope this helped and best wishes.
Sep 02, 2009 | Dryers
Kenmore Electric Dryer M#62932
Check the door switch on the unit. The unit will not run if this switch is bad. Also, the thermal cut out needs to be tested as well. While you are at it, is the element bad? These are some things that can cause the unit not to run.
Apr 10, 2009 | Dryers
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Gas dryer's start button doesn't stay engaged
bad start switch on motor, rare. that model # came up as maytag range not a dryer.
Jul 19, 2008 | Dryers
Washing Machines Logo
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
