Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice maker not working. water is loading but it never spits out the ice. The tray arm never lifts.
Lately, the opening where the ice dispenses on the inside of the door and opening from the icemaker itself has been collecting 'frost' - whether the ice maker is on or off. Now sometimes the ice dispenser doesn't want to dispense. What do you all think is wrong? Thanks.
Posted on Oct 18, 2009
    Sergeant:
  • 222 Answers
You need a new ice maker they typicallly only last about three years
you can check it by removing the cover (white plastic square on the forward end)
and place an insulated jumper wire from "T' to "H" it should advance (remember to hold door switch closed) if it does not advance then you need a new ice maker
Posted on Oct 08, 2009
Freezer wont make ice cubes
This is not difficult to troubleshoot.
  • When the arm is up the ice maker is off
  • When the bucket is full the arm is up the maker is off.
  • If the ice maker has a on/off button in off the ice maker is off
  • If the ice maker internal heater fails the cubes will not release and the white plastic ejector arms will be rotated CCW and pressing against the ice in the tray, Normal position for ejector arms is vertical.
  • If water solenoid has failed or water supply not available the ice maker will cycle. The ice tray will be empty,(hard to see if ice tray is empty). Check and replace water fill solenoid.
  • If ice in tray and ejector arms vertical several possibilities.
    • Freezer not cold enough to trip thermostat in ice maker to initiate release cycle.
    • Check freezer temperature <10 Fahrenheit thermostat in ice maker failure
    • Ice maker motor failure,
    • Internal ice maker electrical connections rotary switch failure,
    The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
Ice Maker Repair
Dec 22, 2015 | GE Monogram Side by Side Refrigerator
Ice maker not getting water on new refrigerator
Check if the unit has a cold water dispenser that it will fill a cup. If so than problem is with Ice Maker. If not than problem is with water supply to unit.
If water to machine works make sure that the arm on the ice maker is in the down position. If it is up it will disable the ice making unit. Cycle the am a few times to insure that the switch connected to the arm has not gotten stuck in the off position.
On some ice makers there is a separate switch to disable the Ice maker usually right on the ice-maker not easily missed.
It is possible that the water feed tube into the Ice Maker has become frozen where it enters into the back of the freezer at the top. You can look through to see where the water fills into the cube tray. If ice is present it would be an indication that the feed tube has become frozen If suspected the safest way to fix would be to turn off the unit and allow for a manual defrost.
Next check the operation of the ice maker. Locate the arm in the up position prohibiting the ice maker from cycling. Wait three hours or more. Open freezer door and return the arm into the down position. After a few minutes you should observe the ice fingers rotating to release the cubes into the tray. If the fingers do not rotate I would suspect the ice maker or the connecting electrical circuit. Remember after dropping the arm the Ice Maker has to warm up to melt the ice cubes from the tray before the fingers are told to rotate,
If the fingers rotate then I would expect that the water supply solenoid has failed inside of the unit near to the location the the water supply is made. Replacing this part needs to be done by a qualified experienced technician.
Nov 15, 2015 | Refrigerators
Water is going into the ice tray but once it freezes the cubes dont come out when the assembly rotates. When it cycles again to get more water the water spills into the dispenser & eventually the tray
can b one or two things wrong here
(1) how sure are u that water is not just continuously flowing into tray (at low rate) ??? reason I ask is a leaky solenoid valve is a very common failure on ice makers
(2) is arm that rotates thru ice tray ,not obstructed by anything ? ive seen Frozen pizza's hold a swing arm down and not allow it to raise to shield the ice tray in a dumping cycle (im speaking of "hold" arm ! thin steel arm that raises up in a ice dump cycle )
(3) of course could be a defective ice maker as well ? theres lots of motors and gears and switches inside there that could malfunction and prevent it from working
Jun 29, 2015 | Refrigerators
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
The ice maker is not making ice. The water filter has been replaced and there are no trouble indicators from the lights on the front of the unit. The house has a water softener for whole house service.
Hello
Where the water comes into the ice maker.Be sure it is not frozen up.If it is, remove ice with a hair dryer.
Also,reset ice maker by lifting full ice tray arm and putting it back down.
Jun 05, 2011 | Maytag MFI2266AE Side by Side Bottom...
Ice maker stopped working. Arm seems stuck
Check to see if your vanes are iced in as the heater element in your ice maker may be on the fritz. This means that you may have to replace your ice maker. Take a hair dryer and direct the heat to the ice tray for a while to see if the ice will thaw enough to allow the ice maker vanes to rotate and re lift the stop arm. If this works and it refreezes again and will not ezect the ice cubes then the ice maker will have to be replaced.
Feb 07, 2011 | Whirlpool Refrigerators
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Icemaker not producing ice
you need to troubleshoot the problem, if the wire arm that tells the ice maker to stop making ice when full is in the upright position the ice maker will not make ice. the problem has to be either the switch on this arm malfunction. but probably in MOST cases it is your electronic water valve which has gone out. this is located on the water supply line on the back of the fridge at the bottom probably behind some cardboard or plastic. it is the same kind of water valve as a dishwasher uses, if it malfunctions it will not deliver water to your tray, manually fill the tray and put the arm down, if the maker dispenses the ice out of the tray, chances are your electronic valve is broken.
Apr 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Water not comming to ice maker
Ice maker is fixed. We unpluged the frig for about 10 minutes and it is now working. Someone else was given this as a solution from FixYa and it worked for me. Thanks
Nov 22, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
226 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
