Question about RCA HD50LPW175 50" HDTV
My RCA 54 in projection tv shows a blurred picture
Hi, my set just suddenly began showing all of the pictures with halo's or shadows. blurred? Letters appear with green, red, and blue shadows. It looks like the color things are misaligned. I have had this set for about 8 years now. Prior to this, I had a beautiful, crisp picture. If it's a simple fix, I can do it. Otherwise, it's $120 for pick up and delivery plus the cost of the repair and supplies. " that is not happening right now. " I see too many $$$$$$$$$$$$$$. I have another problem too. I have a 37in Sylvania flat screen. It will not come on. I've unplugged for hours and replugged. It has not reset itself. Both of these problems occured on Monday. So, I have no TV now. I really think my kids did something. Anyway, thanks in advance for any and all suggestions.
  • RCA Master
  • 5,138 Answers
On the RCA - Color Wheel Encompass Parts Distr look up online or call them 1-800-638-3328 Other TV could have Bad capacitors pull back off if any of the caps are puffed up on top then they are Bad 1000uf 16v , usally find 2 or 3 bad
Posted on Nov 21, 2009
Picture show blurred and 3 lines across the screen color of red, blue and green
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
On left half of the screen [ KP51WS510 ], a redish shadow showing
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Sony KP-51WS500 51" Rear Projection...
RCA projection is having color shadows and blurred picture.
Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
May 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
Red picture
That could be just cold solder joints on your convergence circuit board. I would call a svc co. to have them evaluate it. It's not a major repair.
May 03, 2009 | RCA R52WH73 Projection Television
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Double words and blurred picture,
Is the picture bowed in too. first consult "the fl231 problem" article under the tip and tricks section under my profile. THis MAY be the problem. Otherwise you have a convergence issue. convergence is controled by three cuicit boards in this set. Setting the convergence on this set is tricky. try autoconvergence see how far it gets. let me know and i help you trouble shoot further
Nov 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
54 in big screen phillips hi def tv picture has green shadow all around it.
Does it look like a glowing halo, and makes the set impossible to adjust it out? Please respond to this same post I may be able to help, as it sounds like a coolant problem, very common in phillips TVs
Jul 19, 2008 | Televison & Video
Red shadows to picture and letters on Sony TV
its most likely a warped lcd plate in the optic block if thats the correct model number which would require a optic block change out
Jul 05, 2008 | Sony KDF42E2000 42" HDTV
My rca home theater tv guide plus mod#p52820BL
Can you try using a different video cable?
May 08, 2008 | Televison & Video
RCA HD50LPW175 50" HDTV Logo
241 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
