My hp pavilion f1903 turns on than shutts right off
  • abbyandant Oct 08, 2009
    i did that it does the same thing the pc im on right now works with the screen it has
    My HP pavilion f1903 shuts off right sfter you turn it on screen comes on than goes off power light stays on though.I tried a different pc it does same thing
  • 5,807 Answers
1) there are many possibilities why your HP Pavilion monitor shuts right off
a) one possibility is software related , might be on the resolution
or the driver of the monitor.
b) might also be a hardware , an electronic component /circuit failure.
2) here is a link , for initial troubleshooting of your monitor might
help , try these:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01295035&tmp_track_link=ot_faqs/top_issues/en_us/c01295035/loc:2&lc=en&dlc=&cc=us&lang=&product=348756
3) if the initial troubleshooting still don't and still shuts right off
then you might need someone to help you, open the unit
and measure the power supply output voltages on the monitor,
these only applies if the problem is really the monitor.
4) if it is, saying that the computer turns on and presumed finished
booting, and running, using a flashlight pointed sideways you
can faintly see images then the backlight inverter circuits are not
working.
5) there could be still other possibilities but a visual look and
voltage measurement inside the unit can properly diagnose
the circuit problem you are having.
6) inside the unit there are also possibilities some capacitor/s
or some transistor/s have failed.
7) have someone to help you measure voltages inside the unit
to be precise in isolating stages of which the system is failing.
8) in these case, a lot of care and safety is important, be cautious
on the voltages that might still be stored even there is no power
available., you can safely discharge the capacitors with at least
2.2K 5w resistor.
9) there is also a possibility of cold solder joints even when
some electronic parts are found/replaced and still not working.
10) two most possible causes are the psu and the inverter circuits
11) sometimes on the EEPROM too, refer first on step 2
hope i have helped you , thanks for using Fixya!
Posted on Oct 08, 2009
  • 3 more comments
  • Rommel Cana
    Rommel Cana Oct 08, 2009
    a) have someone to help you open the unit and a visual look is needed.
    b) next would be voltage measurement.
    c) try using flashlight focused sideways if you can see a faint image.
  • Rommel Cana
    if you can see a faint image then inverter circuits failed or your power supply
  • Rommel Cana
    there are indicator lights, please elaborate further the status of the lights
  • Rommel Cana
    Rommel Cana Oct 23, 2009
    these might look like what you have inside the unit
    the one inside the red is a sample of a cold solder joint
  • Rommel Cana
    here is additional guide for you
    Brigadier General:
  • 3,614 Answers
A possible problem on the video card or into your PC, first try to connect and test the lcd into other unit to test if the lcd ws still Okay..
Let me know
HP Pavilion F1903 flat screen monitor dimmer with grey lines
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 12, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
What causes a dark screen and a flashing power button for a HP Pavilion F1903 19" flat screen monitor?
Probably find the screen inverter has failed and needs replacing. Can be a fiddly job as you have to dismantle the monitor so take it to your repair shop if you're not familiar with this type of repair.
Apr 28, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
How do i change my screen resolution on my f1903
You change the resolution at the PC, Right click on the desktop, the display properties will come up, the click on Setting tab to set the resolution. You must make sure that you have correct video card driver installed.
Apr 27, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Speakers don't Work on HP Pavilion f1903 desktop
Just match the color of the male and female on each end. Plug the audio cable (mini stereo phone plugs) to the PC audio line out (green miniphone jack) to the Powered speaker mini stereo phone audio line input jack (green color jack). You will have to set the volume controls of the speaker control knob and at the PC on screen volume control panel.
Mar 29, 2010 | HP Pavilion F1903 19" LCD Monitor
Can not load f1903 software on microsoft xp system
This has nothing to do with your monitor. Windows has default drivers that will be installed for that.
The problem will be your video card drivers are not installed.
Get the right drivers for your card, install them and you should be away.
Mar 29, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
MY HP PAvilion F1903 19 " gone black blank
Problem is generally dry solder joints around the inverter transformer on the inverter PCB.
Feb 16, 2008 | HP Pavilion F1703 17" LCD Monitor
HP F1903 FLAT PANEL POWER PROBLEMS
internal power supply failure in the monitor generally repair is more costly then replacement,that can be verified if you can find a tv repair shop that provides free estimates.
Dec 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1903 turns itself off when connecting DVI
Sounds like your problem is hardware and lies with the port on your PC, this may be due to a bad driver, or bad port! Sounds like you have tried everything else!
Oct 03, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
66 people viewed this question
k24674
jasbo
jasbo
