Question about Conia DVD8500 DVD Player
Mt DVD player has the parental block operational which means that I am unable to watch Law & Order DVDs. I don't have a copy of the default password to change the parental block.
    Brigadier General:
  • 3,614 Answers
LEt me se, wht is the model and maker of the player?
Than ks
Posted on Oct 08, 2009
  • micromaster
    micromaster Oct 08, 2009
    1. make sure no disc is in unit
    2. enter 9735
    3. select Region 0 (will play all regions)
    4. press enter
    5. exit setup
We can't watch DVDs as it says DVD blocked for
your player probaly has something wrong with it and ur tv is telling you not to use, so buy a new dvd playeer
Dec 27, 2012 | Televison & Video
Panasonic DVD player, don't know the parental
You will need to get the parental code from the original owner to unlock all functions.
Apr 07, 2012 | Panasonic Televison & Video
How do I reset the parental control password on a govideo dvd player?
Parental Control
Blocks playback of rated DVDs based on
their content. Not all discs are rated.
1. In DVD Stop mode, press SETUP.
2. Select Others > Parental.
3. Select the desired Parental Control
rating from "1 Kids" to "8 Adult", then
press ENTER.
4. Enter your password using the 0-9
keys, then press ENTER.
• The factory default password is
3308. If you forget your password,
this will always work.
Password
Changes the Parental Control password.
2. Select Others > Password.
3. Enter your old password using the 0-9
keys.
4. Enter your new password.
5. Re-enter your new password and
press ENTER.
Mar 05, 2011 | GoVideo DV2150 DVD Player/VCR
My Memorex 2040 dvd player gives "error parental" when I try to play a dvd. Any idea what this is or how to fix?
The Parental controls for your DVD player has been turned on. The default setting for most Parental Control setup is G rating meaning that anything above a G rating will not play unless the override code is entered. I was unable to locate a copy of your manual, but if you look in your copy for a heading called Parental Controls, it should explain to you what has to be done to either change the rating or remove the control altogether. Unless you have small children that may use your player you can probably remove the controls altogether. Normally you would have to go into your Setup menu, and then look for Parental Controls in that menu. Unless someone setup a code, you should be able to go in and just turn it off. If there has been a code applied and you are unable to find out what it is you will have to contact Memorex support to find out how to remove it. To ensure that it doesn't get turned back on you might want to hide your remote, as you need to use it to turn the feature on and off.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 16, 2011 | Memorex MVD2040 DVD Player
How can I change the parental control? Somehow the parental controls are set on the DVD player and it will not allow me to play certain dvds without a password
Unfortunately there are no known ways to change the user code. The parental controls are set because it's a DVD player for kids - and you must input the password every time you want to play a DVD.
1369 is the code to allow you to play blocked movies. I still haven't found a way to change the level. Again, you have to input the code each time. I know it stinks, but I guess they didn't think of the parental feature in its entirety.
Jun 24, 2010 | Disney Ramone DVD Player
Can I downlosd a DVD to my player?
not unless the dvd comes with the digital copy. you are unable to copy dvds onto ur computer, due to copy right law
Jan 09, 2010 | SanDisk Sansa Fuze MP3 Player
Password reset
The Rating menu allows you to block playback
of DVDs based on their ratings.
Setting the Password & Rating Level
The DVD player allows you to block playback
of inappropriate content with a passwordprotected
Rating system (not all discs are rated).
A. From Stop mode, press SETUP.
B. Select Rating and press ENTER.
C. Select Rating and press ENTER repeatedly to set the rating from 1 (most restrictive)
to 8( least restrictive ).
If a password has already been set, the lock icon will be closed. You will not be
able to select Rating until you SELECT the correct password using the 0-9 keys.
D. Select Password.
E. Use the 0-9 keys to SELECT a 4-digit password and press ENTER. The lock icon will
close to indicate that the rating and password are set.
F. Press SETUP to save and exit.
Not all DVDs are rated.
DVDs that are rated higher than the level you select will not play without SELECTING
the correct password.
If you forget your Rating password, select 8888 to clear the memory. Keep this password
out of reach of children as if will always unlock the Parental Control setting.
If you need more help you can get the full manual from
http://www.retrevo.com
Thanks for using fixya
Aug 01, 2009 | Astar DVD-3800
Parental block password
Hi.
Providing you never put one in of your own The default password is 0000
http://dysonmanuals.llc.nu/
Chris.
Feb 20, 2008 | Daewoo DV-6T955B DVD Player/VCR
Parental Control Screen
Order a remote on Ebay for about $5 to $10. Default password is 0000. Goodluck.
Nov 03, 2007 | Boss DVD-4200B Car DVD Player
Televison & Video Logo
22 people viewed this question
Top Conia Televison & Video Experts
degroot2940
ray gallant
Are you a Conia Televison and Video Expert? Answer questions, earn points and help others
