Question about Sony Cyber-shot DSC-W50 Digital Camera
What does E:91:01 mean? I get the error message when I turn my camera on and the flash will NOT work. Please help. Thanks,
    Habit-Forming:
  • Sony Expert
  • 163 Answers
E:91 is the purticullar flash failer error itmeans you may chang flash unit please go to your nearst sony service centre & fix your problum
Posted on Oct 09, 2009
Nikon D5100 Autoexposure error when camer is first turned on
Hi I'm having the same problem!!!
My Nikon D5100 camera giving a sin of Autoexposure error after it's drooped from my tripod on the deck floor (Wooden Floor). How can I fix that? I tried few does not work, please help me, it's an emergency. Thanks!
Aug 28, 2012 | Nikon D5100 Digital SLR Camera With...
When i turn on my fuji polaroid cam, there is an "E" error message. I can't take any polaroid pictures with it altho the polaroid cam is loaded with film. Please help. Thanks
First, remove the remaining films from the camera. (while your camera is switched off) Second, press on both the shutter button and the power button at the same time. (to reset) Third, reload a new set of polaroid films into the camera.
Hope it helps!
Dec 26, 2010 | Fuji instax mini 7S Film Camera
Sony DSC-W50 camera Error msg E:91:01
Please follow the instructions given below
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Second step:
1)at setup do a initialize.
2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Flashing error message C:31:23
Hi Jazzy,
Please see the detail below for the said error codes C31:23.
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Jan 09, 2009 | Sony Handycam DCR-TRV240E Digital...
Hi I have a sony cyber shot dsc t20 and I get an error message flash settings cannot be changed whe I try and select another flash setting?
I had the same problem, and i tryed everything, even opening
the camera and see if any visible damage on any part (nothing), so
when i try initializing again ( menu>setup>option #1), right after the
"OK" over reseated date, i went to the Flash Button, and turn it off
and at least the annoying flashing error is not there - that means it is
software error, because all flash functions work till it detects that
has ans error wile charging/loading the flash. Hope it helps.
TENFERRE
Aug 25, 2008 | Sony Cameras
Error message is F--
Well, it looks that FE message means that the camera is confused. I saw this message when I put a non-D lens and automatic TTL flash  (which does require D lens to measure a distance). Usually putting the camera (or flash in my case) into manual mode got rid of the error.
Jul 03, 2008 | Fuji FinePix S2 Pro Digital Camera
Turn Camera Off error message
hi
I have the same error code if you can help me please let me know
thanks a bunch
Jun 29, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
DSCH9
Guys - I just recevied a new H9 today. Was using it and decided to turn the flash off. Later on I wanted to turn it back on and I got the famous "flash settings cannot be changed" error message. I found the problem. I had turned on the "continuous shooting" option as I wanted to see how fast it would take photos continuously. When that option is on, you cannot use the flash so therefore you cannot change the flash settings. I put the camera back in "single-shot" mode and now the flash works fine. I hope this fixes your issue.
Thanks, Ken
Nov 23, 2007 | Sony Cyber-shot DSC-H9 Digital Camera
Error message on display
Had the same problem, turn on camera wait until power up is complete and turn it off again. Give lens area a firm hit and turn camera on error should be fixed. try several times as it may not work first time. This worked for me hope it helps
Oct 16, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Camera shows an error E30 message
Hi Chittu, This error usually happens when there's problem reading and writing from the Flash memory card (CF). Did you try to pull the memory card before the camera finished writing data? Here's what you should do - try using another memory card. If it works, it means that the original one is damaged. Let me know if this helped. Please rank this post.
Mar 05, 2007 | Canon PowerShot A75 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
447 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
