Question about Honeywell ER150B Air Conditioner
My Honeywell Cronotherm III says "replace batteries" but I bought brand new ones and it still says the same thing. I can't get it to do anything!
  • 89 Answers
There should be a reset button inside the t-stat, press this button and let it reset and then reprogram.
Posted on Oct 08, 2009
Honeywell chronotherm iii died
did you check for correct positioning of new batteries ? also when but back on base is it securely attached?
Nov 19, 2013 | Heating & Cooling
All I need to know is this: The Chronontherm III died (my house is 20 years old and I believe it was original to the house) and I need a new thermostat. Can I replace the Honeywell Chronotherm III...
Yes, you can replace with that...just make sure that you mark the wires BEFORE removing them...so you can place them on the same terminals on the new t-stat...
Here is a list of each common terminal and what their commonly used for. Also listed is what colors are commonly used. NEVER ASSUME these are what you have. Verify all your wires by following each to each piece of equipment. This will help you to be able to match your equipment with the terminal.
Here is the rest of the tip that I wrote...
Thermostat Wiring and Terminal Designations
heatman101
Jan 11, 2011 | Heating & Cooling
A/C won't come on, replaced batteries, display reads -AC Honeywell chronotherm III Thanks for any advice !!!
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 07, 2010 | Honeywell Power Humidifier: Furnace...
We have a Honeywell T8132A1049 thermostat/ cooler- we can't find a manual for it. It also says Bat Low on the screen but I have replaced the batteries with brand new ones and tried resetting it .....
Here is a link where you can download the user manual. It says to remove the batteries, wait 1 hr, then install fresh batteries. When the page for diplodocs opens click on security number and enter the code it shows to download the manual.
http://safemanuals.com/314159.php?k=af5d595162dd03d6ac627239ba1fbecf&ID=530143&q=HONEYWELL%20T8132A
Jun 08, 2010 | Honeywell Heating & Cooling
My honeywell chronotherm III says -AC any ideas
The problem is your 24v power source. I am unsure as to why you put "other than power source or batteries". If you did indeed check that your thermostat is receiving 24v, then I would say that you have a bad thermostat. Hope this helps
Jan 22, 2010 | Heating & Cooling
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate batteries, turned the correct way. Cleaned off the battery terminals and still have replace battery...
Thermostat problem; Honeywell chronotherm lll ' Low Batt. indicator Keeps blinking after Batteries replace. I chk'd batt. with elect. volt ntr. Was told to pull batt. and change ends with them , letthem stay reversed for 5-10 sec. then put them back in right order,and replace thermostat. No success!
Anyone have any answers
Nov 12, 2009 | Honeywell Power Humidifier: Furnace...
Honeywell chromotherm iii says and beeps low battery, even though i just replaced the batteries
check that the springs on each end of the batteries are keeping them together tightly (connected) if thats not it the only other option is to replace the stat
Oct 18, 2009 | Heating & Cooling
I have a honeywell control unit that has a corrosion problem in the aa battery compartment, When I change the batteries every 12 months I notice it is getting worse. I put a new set of batteries in and the...
Your problem is bad connections due to corrosion. If you would do something to correct that you wouldn't need to replace anything. Batteries ooze acid when they go bad, to counteract that you need to apply a paste of baking soda with water on a used toothbush and scrub all the funky stuff away. Paper towels are good to wipe it off with until it's dry. Take a small file or a small piece of sandpaper and dress or shine up the metal parts that contact the batteries and then spray the parts with contact cleaner from Radio Shack. Your batteries need to be changed BEFORE they purge their innards all over your good work next time - don't let it happen again.
For exact parts replacement you might find some honeywell numbers that may actually make a hit on Google. Even the most bizzare combo of Alpha and numeric gibberish in quotes will sometimes yeild pure Google gold. Other than dealing with a honeywell employee, I have no other suggestions on hunting down your part.
Sep 06, 2009 | Honeywell Heating & Cooling
Replacing aging erratic honeywell chronotherm III
Hi, your replacement part can be purchased on amazon, take a look here: Amazon com honeywell chronotherm III thermostat. I hope this was helpful. Cheers
Nov 30, 2008 | Honeywell Programmable Thermostat Heater
Replacing thermostat for central heat and air/ not humidifier
rh and rc should have a jumper between them.connect red to either.y=yellow g=green w=white and do not use the blue.your new stat will run on batteries.
May 26, 2008 | Honeywell Power Humidifier: Furnace...
Honeywell ER150B Air Conditioner Logo
62 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
