Question about Admiral AW22 Top Load Washer
Noise in the wash cycle my washer makes screeching noise like the agitator or drum is rubbing the sides or bottom. have tried lighter loads, re-positioning the clothes and it does this on all load settings....any ideas?
  • Anonymous Dec 26, 2007
    i have an Admiral capacity plus and it has been doing the same thing. sometimes it spins fine other times it walks across the floor and makes banging noise. i have tried everything; my husband has shifted it checked to make sure it was level and it was. still does it. other times it works fine. no rhyme or reason.
  • 883 Answers
High probability that an object, that had escaped notice during loading of clothes, has been "tossed" over board the wash tub into the outer tub. Most washing machines are constructed this way (two tubs, one move-able, one stationary) to prevent this object toss, but somehow they still get tossed. Solution is to remove the object and methods vary from simple (use magnet snake retriever if object is magnetic) or use mechanical snake retriever (has tiny pliers at far end of wire) to extreme by removing inner tub.
Posted on Dec 24, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Hi, I have a frigidaire front load washer, model FTF2140ESO, that is making a high pitched screeching noise when it enters into the final spin cycle. The noise ramps up in volume as the drum spins faster....
Some times screws can work their way out near the drum and rub against the drum causing the squeak. You might have to take off the back of the washer and see if there is anything loose contacting the drum.
Oct 16, 2013 | Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Clacking sound on agitate cycle only, no noise on spin
The agitate cycle uses the motor and a spring to function. The spring is made in pieces and asit gets older some of the sections of the spring break. To verify that it is not a loose drum. Ope the washer during the wash cycle andhold the drun by hand. If the noise stops lool for the loose bolts or replace the springs, they may be weak after that many years.
Aug 18, 2009 | Washing Machines
Agitator was screeching, now there is grease/oil stains on clothes
Main seal and bearing have gone bad and needs to be replaced
Jun 02, 2009 | Washing Machines
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Noise in my washer while agitating
Maytag have had some problems with the bases of the unit. If you open the lid and it is leaning to the right this is the problem. You have to change the base of the unit and the springs that come with it. This is the only correct fix, but is a costly one.
Sgt 48
Jun 03, 2008 | Washing Machines
GE Model WHDSR209D2WW makes unbearable loud metal Screeching noise
ppr78, couple of things you want to check. The bottom panel on these GE's are pretty flimsy. I have run into a couple where during agitation the bottom of the motor housing would rub against the bottom panel making a terrible noise. You need to remove the front panel by pusing on the clips on the left and right side just under the top. The front panel will pull out. During agitation, take your foot and push down on the bottom panel and see if the screech goes away. I have also found the suspension rod support sockets at the top dry out and make a screeching noise. You also want to check your belt and pully and see if the noise is from there. Check these things first...Catriver..post back.
Jan 12, 2007 | GE Profile Prodigy WPSE4200A
Admiral AW22 Top Load Washer Logo
147 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Marvin
Marvin
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
