Question about Kenmore Refrigerators
Water wont go all the way into the ice maker
I have water that runs to my water dispenser and its perfect, however the water doesnt seem to want to go into the ice maker, sometimes you can see the water get up about 3/4 of the way in the hose but then for some reason it stops and slowly starts draining back down... any help is appreciated to save me from spending 100.00 or more for a .50 cent problem
  • dougjmb Oct 08, 2009
    sorry if i sound stupid here as i'm not a manly man i guess because i dont know alot about handyman situations. I've taken the water valve off the back of the fridge and was going to switch the water and ice hoses to see if i switched them if the water would go into the ice tray maker at all, but the hoses are 2 different sizes so i was unable to test it that way. How do you check the filter? Is it in the water valve connected to the back of the fridge? And if so what part of it? As i was looking at the valve i saw the water / ice hoses and then 2 other hoses connected to it as well so i'm not sure where to look. As i've stated the water dispenses perfect... its just the water that supposed to go up the tube to the ice maker will only go about 3/4 the way up then stop and slowly drain back down.... i thought also at the top of the tube maybe it could be frozen, but as we just bought this fridge off of craigs list about a week ago, and havent had the water to the fridge turned on until tonight, i don't see that as being an issue
    also tried to switch the wires that woodchuck789 suggested but as with the water hoses they are 2 different sizes so was unable to test it that way as well
  • 4,066 Answers
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Or
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Oct 08, 2009
  • Charles T Nevin
    Charles T Nevin Oct 08, 2009
    There is a mesh screen on the water inlet valve where the water comes in. Make sure it's clean and while you have it disconnected let the water run into a bowl to get any sediment out and to see how much water pressure you have. Disconnect both lines coming out of the valve and try the dispenser to check the water flow. Since the wires won't fit you can swap them by using insulated gloves or insulated pliers or any other idea you can come up with and try the dispenser to check the water flow on the ice maker side of the valve. While you have it disconnected try blowing through the ice maker line to see if it's clear.
    The ice maker side of the valve may not be opening up much, causing your problem.
    Sergeant:
  • 222 Answers
Check water pressur and check for leaks in the entire system, check if filter is clogged
if that is all ok replace water valve
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Ice maker freezes water in tray but doesnt dump
my ice maker empty but don't seem to empty the whole tray out what could cause that
Aug 26, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrigerator (frigidaire plhs269zdb9) wont make ice.
maybe bad ice maker or water valve. start whit the cheapest. water valve.
Apr 02, 2010 | Refrigerators
I have a GE Refriderator about 3 years old. Recently the water dispenser stopped working, and the ice maker stopped as well. The ice maker seems to freeze up as it dispenses water in the tray to make ice....
Are you having any cooling problems whatsoever, anywhere? Is there any area in the unit that you dont put food for cooling reasons? if cooling is fine, check the water pressure as it comes into the refrigerator, you wil have to disconnect the water line at the solenoid valve behind the fridge. If pressure is good, pour 4-8 oz of water into ice maker, does it eject those cubes within 24 hours? then replace your water valve(s) One assembly houses a solenoid for both the ice maker and the water dispenser, both solenoids are bad.
If you have further questions, visit my website and send me a question. www.FixMyFridge.net
Mar 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker will not dispense water or ice.
sounds like maybe the switch that is press to release water not working so it doesnt sent the signel to let water out dispenser
Sep 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice dispenser wont work....ice maker works
Need to check and see if the water filter is stop up ,if you don't have a filter it I would start with water value at the bottom .
Mar 14, 2009 | Refrigerators
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Maker Dispenser is not working.
thanks for the question looks like the ice maker does not cycle there is a electric motor that turns on to drop the ice seems like that doesnt work looks like you need a new ice maker Thanks for the questiuo The appliance doc
Sep 11, 2008 | Kenmore 53603 / 53606 Stainless Steel Side...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Refrigerators Logo
250 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
