Question about Canon PIXMA MP210 Photo All-In-One Printer
Does not print code error says paper jam and it does not feed the parer thrugh but u can hear the printer working as if the paper was being fed cannon pixima mp210
  • 117 Answers
When an ink tank becomes empty.
("No ink error" displayed on the
monitor or on the machine LCD, or
short flashing of an ink tank
Posted on Oct 09, 2009
Solution for error code 005-196
This is essentially a paper size mismatch which causes a paper jam. Technically you submitted a print job for a paper size that did not match the paper which was fed into the printer. Example, your document is legal size but the printer pulled a letter-size paper. As it passes through internal sensors along the paper feed path, the paper size doesn't match the document size (created on the PC) and so the printer stops with the paper in its path posting the error and causing you to have to remove the paper from the jam area. The resolution is either provide the correct size paper based on the document settings in the PC application (may need to be fed in the printer's manual paper tray) or change the document size within the PC application to match the size of the paper being fed into the printer. (Paper size can also be modified in the printer settings on the PC.)
Nov 18, 2014 | Xerox WC7232 Printer
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
May 30, 2013 | Brother MFC-7840W Multifunction Laser...
Paper jam/no paper fed
make sure the photo paper is in glossy side face down,
set the paper type to photo.
If it keeps jamming it's because the paper feed is probably dirty and not taking the paper properly
Mar 24, 2010 | Brother DCP 130C All-In-One InkJet Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
Oct 24, 2009 | OKI C5500n Printer
Epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Apr 17, 2009 | Epson Stylus C86 InkJet Printer
Printer always prin at the to of the page and then it will parer jam but no paper is in it to jam up I have a canon bjc-4200 and I like the print that it dose
hi there,
This problem mostly caused by another material (such as broken paper, etc) present in paper path prevent paper to reach paper cam sensor. Check inside your printer and clear paper path from another material. You can also try to clean paper feed roller. If problem still persist, replace paper feed roller
Regards
Source:
Canon Inkjet Forum
Nov 09, 2008 | Canon PIXMA iP1600 Printer
Paper tray won't feed paper & I get a false paper Jam code
This might work for you - it worked for me. HP paper was feeding crooked. Checked the "Paper Type/Quality" in the printing options window - mine was set to Photo Paper. When I changed it to Plain Paper, the paper fed evenly. Hope this works for you.
Oct 31, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Jan 04, 2008 | Brother HL-2040 Laser Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
172 people viewed this question
old marine
old marine
