Question about Kenmore Ovens
My oven will not turn off even after I turn it off the temperature gets hotter and hotter. I have to unplug the oven
    Sergeant:
  • 222 Answers
You have a bad main control board
a relay is stuck on the main "clock Board"
replace board
also may want to check or change temp probe in the upper corner of the oven cavity
most probably bad board
Posted on Oct 08, 2009
Temperature when using frigidare oven, keeps getting hotter and does not cool down
Good Afternoon Andrea,
I see that you're having issues with your Frigidaire oven, and the heating element being red hot the entire time you were cooking no matter how much you turned the temperature down.
I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your oven, you will need to set the clock by entering in the time and pressing start. Preheat the oven, to whatever desired temperature, and if it is still running hotter than it should be, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 22, 2014 | Frigidaire Ovens
Hi there The oven burner is always on high ,even when I turn it on 200..
The oven burner will usually always be on high, until the thermostat reaches the desired temperature and then will shut off the burner until the temperature drops and then restart on high again. If your oven is getting hotter than what is selected then it could be the thermostat that is not working right.
Jul 13, 2011 | Ovens
Oven runs much hotter than set temperature. Usually 50 degrees hotter than what it is set at, but can go over 100 degrees higher.
Sounds like you need a new oven thermostat or get an oven thermometer and by experimentation draw up a new heating range for the oven dial.
Feb 11, 2011 | Frigidaire Ovens
Are gas oven does not get any hotter than 250 degreese c
that temperature is almost 500 degrees f. how much hotter do you need it to get??
what other problems are you having?
Jan 12, 2010 | Maytag CWG3100A Gas Single Oven
When using the oven setting it justs get hotter and hotter.
tt sounds like the thermostat sensor
Dec 27, 2009 | Ovens
Oven gets hotter than temperature set
I don't know if there is a solution but I kbow every model like this does the exact same thing. I two of my family members have the same stove and they have the exact same problem.
Oct 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
Sep 16, 2009 | Ovens
Ovens Logo
82 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
