Question about Bosch Exxcel KGV35421 Bottom Freezer Refrigerator
Dodgy fridge light
Our light in our Bosch Exxcel refrigerator freezer does not always go off when the door is closed. The door seems to have dropped to be too low to hit the sensor. What can I do to heighten the door?
  • revtim Feb 08, 2008
    I have exactly that problem on a Bosch Exxcel fridge. The door has obviously dropped (probably compromising the seal - there is excessive condensation in the fridge) and affecting the light switch too.
    I assume there is a way to adjust the lower hinge, but I haven't managed to work it out yet!
  • Anonymous Mar 31, 2014
  • 833 Answers
Generally, these doors drop from excessive weight, a warn part or loose fittings. Unload the door and investigate. You may also want to check that the unit is levelled...the box may be warping/sagging...although this is unlikely.
Posted on Dec 24, 2007
Fridge door magnetism does not work - when closing door does not pull shut?
if it's new or recently been moved for some reason, Making a minor adjustment to the front wheels, slightly positions your Refrig. so that a rear-tilt causes gravity to allows the doors to close, assisted by the weight of food products on the door.
If you've had it for some time, You might want to check and clean the metal surface area and the door gasket on the hinge-side. As a habit, cleaning door gaskets, with soap and warm dish towel, will preserve the life of the gasket and save you couple of bucks down the road.
Aug 28, 2013 | Bosch Exxcel KGV35421 Bottom Freezer...
Bosch Exxel KGV28323 fridge freezer. When door is shut the light goes dim but not completely off. Thinking a dodgy contact might be the cause. Have replaced the switch but no change. Have rcd fitted and...
I thought the same with mine, but its supposed to, there is a switch near the thermostat, if you turn it off the light will go off when the door is shut, you are supposed to leave it on if the room the fridge is in is under 18 degrees, the heat off the dim bulb stabelises the temperature and keeps the freezer working
Jul 02, 2011 | Bosch Exxcel KGV35421 Bottom Freezer...
Bosch exxel fridge freezer should the light go dim when the door is shut and not off completely
the light should go OFF when the door is shut.(that is if ive read your question correctly).
Dec 18, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
There is a buildup of ice behind the lower section of the plastic back panel which eventually prevents the door from closing.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Dec 15, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
How to take doors off Bosch Exxcel KGH39A07GB
I've just had to do this - a real pain, and you would think that Bosch would include it in the instructions or somewhere on their website!
You have to put the fridge/freezer on its back (putting a cushion or something like that at the top to make sure the back doesn't get damanged). Starting at the bottom, unscrew the three bolts holding the bottom door in place, then the middle hinge between the fridge and freezer, and then the screws at the top holding the fridge door in place. Then reverse everything round (you may have to make holes where there are dimples on the top of the freezer door/bottom of the fridge door). Good luck!
Sep 19, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
Hi can you tell me what the red explanation mark on my bosch exxcel frost free version fridge means please. mike
it has a problem and its telling you this,,,most likely its to warm inside of it this could be the thermostat playing up
Jul 04, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Bosch KGU31124 Freezer Not Working
I have the same freezer and get the same problems. Ice forms on the refrigeration fins beind the plastic shroud at the rear and completely blocks the airflow. The fan that moves cool air around does not work then and freezer temp goes up. Ice will often push the shroud forwards so that the door does not close properly. Warm moist air get in and just increases the ice problem.
I take the shroud and fan housing off the rear (4 screws and a wire to the fan) and defrost thoroughly using a hair dryer. You can then see when all the ice has gone..
Sep 18, 2008 | Bosch KGU31124 Bottom Freezer Refrigerator
Bosch Exxcel KGV35421 Bottom Freezer Refrigerator Logo
492 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
