Question about Epson Stylus 1400 InkJet Photo Printer
Print Heads snagging paper
Brand new printer.
As the print head assembly passes back and forth printing, (looking at the front of the printer now) as the assembly passes from the left, to the right, it catches the paper ever so slightly on the left side, and leaves a black smudge.
This problem does not occur on the right side with the assembly traveling from right to left.
Any thoughts or suggestions would be greatly appreciated.
  • Epson Master
  • 1,879 Answers
Well if u have a straight paper - it´s the printers fault
ask for a replacement from the place of purchase or from the manufacturer
Posted on Jan 03, 2008
Clean print heads brother MFC J425W
This is what I figured out to get the printing back to normal.
Open up the printer so you are looking at the place where the print heads go back and forth, you will also see the paper feeder. In the back left corner is where the ink is dispensed. There was build up on mine. As usual grab a 10 or so q-tips and some rubbing alcohol and clean the build up of goopy ink.
You won't ever get it completely clean because more ink will keep dispensing. Close it up and run a test print again.
Jan 25, 2013 | Brother MFC-J425W Inkjet Multifunction...
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Error code 6A00
The 6A00 is a Canon generic code for paper path jam. Somewhere in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if it is jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs Incidentally, the 6A00 error pertains to all Canon printers made in the last several years; it is not just used in one model. And it is always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow. Move back and forth several times (with the power off)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 12, 2011 | Canon MP830 All-In-One Printer
When trying to print from the cassette get paper jam error but no paper is jammed. It doesn't even pick up the paper in the cassette. The error will not clear. Any suggestions as to what to do? It will...
The 6A00 is a Canon generic code for paper path jam. Somewhere in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if it is jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs Incidentally, the 6A00 error pertains to all Canon printers made in the last several years; it is not just used in one model. And it is always a paper path error or purge unit.
Dec 08, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Loaded print brand new black/yellow and cyan/magenta print heads and printer and HP Easy Care say I need to load cyan/magenta print head.
This issues looking printer head problem. check the following Steps for cleaning printer head :
  • Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
  • Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
  • Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
  • Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
  • Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
  • Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Oct 02, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
HP Designjet 500, I have replaced the black print head twice, the first new print head would align and then fail the color calibration, the second new head aligns and pass's color calibration, but when I...
it seems there r some air in ur ink tube *** inser the priming heads & done the priming & reinstall the print heads if problem not resolved replace the carridge assembly,,,,,,,,,
Jun 03, 2010 | HP DesignJet 500ps (42 in.) InkJet Printer
Canon BJC-3000. Paper goes through but is blank.
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 24, 2010 | Canon BJC 3000 InkJet Printer
Pixma 830 error code 6A00 on printer screen. Error 5C10 on computer screen when trying to print from computer. Tried moving ink tanks back and forth, shut off computer. Moved white thing to unsick ink...
Hi there
This answers with a titch more detail.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
Also clean the purge unit out make sure all is clean.
Mar 08, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Servicefeil A600
Hi there
Error A600
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
Almost 90% of the time is related to the purge unit being jammed with something and not being able to move.
Look for paper, paper clips, push pins, screws flower bud pods or the like.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow.
The purge unit is a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail.
You can try moving it back and forth about 5 times or so and clean the rail with a cleanex and putting a little bit of some light oil on it and then close everything up and try it.
If you found this useful all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Feb 26, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Service error 6A00
It looks like the print carriage was stuck. Turn on off the printer, manually move the ink cartridge back and forth a few times, look underneath for dirt or small piece of paper (usually happens when you have jammed paper) or use a blower to clean any foreign objects.
Apr 27, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Epson Stylus  1400 InkJet Photo Printer Logo
120 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
