Question about Jenn-Air Ovens
Jenn-air stove Model SCE30600B. Won't heat
Got a old Jenn-air stove Model SCE30600B. The oven blew the heating element. Replaced element, but now the element won't heat. I think it might be the relay. Is there a internal test? If it is the relay, do I have to replace to whole relay board or can I just replace the relay? Where can you find the relay?
    Sergeant:
  • 222 Answers
Check all the wiring at the main bus, and at the board connections could be a bad board
Posted on Oct 08, 2009
Baking & broiling elements won't heat after baking element burned out and was replaced.
the surge from the original element burning out has destroyed the control board if you can't hear the relays on the board clicking when you power up the elements bake or broil then its either the low voltage side of the board,if you hear clicking then the relays are working but the contacts are burned out and can't pass the current to heat the oven or briol elements
Jan 04, 2013 | Jenn-Air Ovens
It's a Model JJW8530CAB. The baking element
Are you having any issues at all with the display at all? Did this start out of the blue or did you have a power outage or anything else?
Jan 20, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
I have a Jenn Air W131 model wall oven and I believe the lower heating element needs to be replaced. I will set the temp at 350 and it doesn't heat up at all. Is my assumption right that that is what...
If this is the problem no it isn't hard at all. Should be able to change right thru the oven without pulling out of wall. Make sure power off while doing this tho. But ist make sure broil does work.
Feb 01, 2010 | Jenn-Air JJW8330D Electric Single Oven
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Oven is no longer heating
If this is an electric oven you probably need to change the heating element. If it gas check to see if the pilot is lit
Nov 24, 2008 | Jenn-Air Ovens
Oven and stove top not getting hot.
The most probable cause is that the heating elements are getting 110V instead of 220V. Check the voltage to the heating elements.
Sep 07, 2007 | Ovens
Ovens Logo
311 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
