Question about Belkin Computers & Internet
My router is connected correctly but the wireless light is not on
  • 24 Answers
What kind of router ( brand, and model ) please.
Posted on Oct 08, 2009
Cannot connect to 192.168.1.1 to set up wireless in my router
If you fail after ping your IP address then it may be problem in your physical connection,so you should check connection like:
check cable modem status light. If it is solid green, it indicates that your cable modem has a good connection. If the light is off, check modem's physical connection.
Verify that the Internet light on your wireless router is solid or blinking green. It indicates a good connection and correct wiring. If the light is off, check the Ethernet wire's connection between your modem and router.
May be it can be cause of Incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.
***If you need any kind of technical assistance you can contact support cell at here
Feb 01, 2013 | Actiontec GT704WG Wireless Router...
Cant connect ,no light on wireless connection. was
you need to setup the wireless connection if you havent already and your router needs to be a "wireless" router in order to create that type of internet connection. Have you laptop then scan for one which would be the one you just made and input the correct information to connect. If that doesn't work I'd suggest getting a new wireless router
May 06, 2010 | Belkin F5D8236-4 Router
I just bought a Belkin Router Model # F5D8236-4. I have everything wired correctly, but the wireless light does not come on. I can't get the internet to come on to the computer I want to connect to? What...
Wireless light will lit up only if any wireless computer is connected to Belkin's wireless network.
First, connect to Belkin's wireless network that you can scan.
After you connect, try to go online
It ll work...
Jan 21, 2010 | Belkin (F5D8231-4) Wireless Router...
Wireless indicator light doesn't light up and
The "Wireless" light doesn't indicate that wireless is available, it indicates that wireless is being used.
You need to narrow down your problem statement by what symptoms you are seeing. Does your PC "see" the wireless router? Does the router accept your connection password?
Then follow the troubleshooting script in the user manual at
http://downloads.linksysbycisco.com/downloads/WRT150N_ug,0.pdf
Nov 25, 2009 | Linksys Wireless-N WRT150N Router
The wireless light is not on and I can't connect to my network
If the wireless light is not ON that is a sign of a bad router to correct this better reset your router, by pressing the reset button for 15 seconds and then after that check if the wireless light is ON and then reconfigure the router.........
Oct 25, 2009 | Computers & Internet
Power light is red. Hub is OK. No wireless and Internet connects
Have you tried configuring your wireless settings? If your internet works hard wired, its just the wireless settings that need to be configured. Access the router's setup by going to http://192.168.0.1 and change the wireless channel. Make sure to check the wireless security as well and verify if you are using the correct wireless network key
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Belkin G Wireless Router Connection problem
Sounds like a faulty router or issue with the firmware if it is unaccesible, your best solution is to factory reset the device and try again.
Regards,
Kris
Mar 17, 2009 | Belkin (F5D7230-4) Router (587009)
The lights are on but the linksys is not working
Certainly if the conection directly from the router to the computer is not working then the wireless won't work. So that's where I'd start. Cable connections could be an issue. The connection without the router works I assume. Make sure you are connected correctly. You need ethernet cabling to the ethernet, networking connections to and from the internet device to the computer and into and out of the router. When you get the direct router connections working you can solve your wireless problems.
Sep 24, 2008 | Linksys Wireless-G WRT54G Router
Can't get online with laptop
i assume that you're connecting your laptop wirelessly. if so, check if the laptop is connected to the wireless signal of the router. there would be a wireless icon that can be usually found at the bottom right hand corner of the screen (if you are using windows but if your laptop is a mac, look for the airport icon) that'll detect the available wireless signals. make sure to connect to your own network and enter your correct wireless security (network key) if you have enabled it.
hope this'll help you but in case if not, just provide the exact model of your router, the model of the laptop, your operating system and the model of the wireless card.
May 26, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
