Question about Radio Shack (15-2147) Remote Control
Remote 15-2147 need codes and programing setup
Need codes for 3 in one remote 15-2147
Posted on Oct 21, 2009
    President:
  • 1,126 Answers
Http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=radioshack&dv=universalremote&md=1521473in1easytouse&kw=&st=&ar=&dt=&so=&pg=3&file=others/radio_shack/152147-manual.zip
This file is in .zip format. It will need to be unzipped (extracted) before viewing. It contains instructions as well as codes needed for your 15-2147. You do have a version of adobe reader also?
Posted on Oct 08, 2009
Reda
Posted on Oct 24, 2012
I need the remote code to program a Memorex television.
039,031,036,033. Try these codes. If you wish to get more codes and other details. It has setup code list, and setup procedure to may popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 27, 2013 | Televison & Video
I need program code for vizion tv to program my DTA800B1 remote
0029,0027. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 17, 2013 | Televison & Video
Need program instructions and code for my jvc tv to program remote
0172,0111,0193,0139,0144 are the codes to check. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 16, 2013 | Toshiba SER0135 Remote Control
I need programming codes for samsung ak-59-00104k remote
1865,1829,1835,1855. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 15, 2013 | Samsung AK59-00104R Remote Control
Need to program a ge universal remote to operate a magnavox sdtv box model #tb110mw9 please get. The codes
There is no setup codes for magnavox SDTV box with this remote cotnrol. If you wish to get setup codes and other details to your SDTV box, check this link. There are setup codes to other brands of remote controls, by which you can select one, which have setup codes to your device.
Feb 12, 2013 | Televison & Video
I need Dynex tv codes for universal remote programming
Hello
Jensen remote has no setup code with Dynex tV. Avex-6 universal remote has setup code for Dynex TV. The code is 399
Mar 22, 2012 | Jensen JR300 Remote Control
Have RCA remote need code or no how to program it to my magnavox dvd player
Hello
Setup codes for Magnavox DVD with RCA RCU-404 universal remote control are:
057, 060, 074
OK.
Jul 19, 2011 | RCA RCU404 Remote Control
How do i program this remote control Radio Shack 6-in-1 Easy Setup Voice Remote Remote Control Easy remote
Turn on the unit to be controlled manually. Press and hold Setup until the voice prompt starts the programming menu. Press 1 to directly enter a code. Press 2 to search for a code. Note at any step if the no buttons are pressed for 15 seconds, the remote will enter the usage mode. Start again from the Setup button. When prompted, press the device button for the device you want the remote to control.
Then enter the 4 digit code (if using the direct programming mode). The LED will blink twice and the remote will announce success. Test if the remote works (play, power) when prompted to test the code and press Setup if it is successful. Then wait until the remote says goodbye and then press Power again. The unit should turn off. (I strongly suggest testing other functions as well after this.) Repeat with other codes if unsuccessful.
For searching through the programmed codes, start as indicated above: press and hold Setup and then press 2. When prompted press the device button. Then press the test key (power usually). Slowly alternate pressing CH+ and power until the device turns off. Press CH- if you miss the device turning off. Press Setup to store the code. Then after the remote says goodbye check if the remote works for all the functions. Repeat the above if it doesn't work for all features.
The manual for the remote is available here: http://files.remotecentral.com/view/852-1041-1/radio_shack_15-2146_6-in-1_easy_setup_voice.html . This file is a PDF in a zip archive and does include the code list at the end.
Please note that codes in the remotes are limited to those for devices released at least 6 months before the remote was programmed. If your device is newer than your remote, you may need a new universal remote. I suspect this remote may be from 2004.
I hope this helps.
Mar 01, 2011 | Radio Shack 15-2146 Remote Control
Directv remote codes
go to menu
setup
setup again
remote
tv
brand
the satelite receiver will tell you the procedure for programing the remote
Nov 14, 2007 | Televison & Video
Radio Shack (15-2147) Remote Control Logo
1,395 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
