Question about Garden
I have a 11 year old homelite zip start leaf blower that worked well until the starter cord became unattached. can i get access to this unit to retie he cord? thanks bill
  • 8,404 Answers
This can be done ... but you got to pay attention while you take it apart. Also, when it is apart, you must visualize how it works ... mane sure you wind it the right way ... put a figure "8" know on both ends. You may need a Torx to disassemble it.
I hope this works for you
Posted on Oct 08, 2009
Homelite blower pull cord frozen how do i troubleshoot it
go buy a new blower, you ran the wrong fuell/oil mixture and seized the motor.
May 12, 2014 | Homelite Garden
Why leaf blower hardly pull to star
RUNNING THE MACHINE WITH THE WRONG FUEL MIXTURE COULD BE THE FIRST CULPRIT. IF YOU WERE RUNNING TO HOT YOU COULD BE DEFORMING THE CYLINDER WALLS AND CREATE A PROBLEM THAT IS NOT FUN. TAKE THE PLUG OUT AND TRY TO SQUIRT A LITTLE WD-40 IN CYLINDER CHAMBER. WITH PLUG STILL OFF PULL CORD A FEW TIMES. SEE IF THAT HELPS. IF NO HELP MOST LIKELY BY A NEW ONE. GOOD LUCK PAL.
Sep 28, 2013 | Homelite 'Yard Broom' Leaf Blower
Starter cord replacement
take apart machine
May 08, 2012 | Homelite Garden
I have a Homelite Mighty Lite 26cs gas weed **** and the starter cord will not retract into the weed ****. How can I get it to retract so it can be pulled to start the weed ****?
This is somewhat common in the the "zip start" machines. The recoil pulley is 2 plastic housings with a round coil spring between them. It is designed to need less effort to pull and start the machine. When pulled on with great effort/frustration, the middle spring bends and damages the upper housing. The only semi-permanent solution is to replace the pulley assembly. The part is relatively cheap thru Homelite.com. If you can do it yourself, go for it. A repair shop will most likely charge you $20 to $40 in labor to do this.
Aug 05, 2010 | Homelite Consumer Products MightyLite...
Starting cord does not retract on my leaf blower (homelite)
take off starter mechanism, replace coil, or recoil if undamaged. then replace starter rope
May 14, 2010 | Homelite 'Yard Broom' Leaf Blower
My Homelite mightylite blower vac starts but won't stay on unless choke is closed down the unit is only one season old. The unit is supposed to be in warranty for two years but Homelite said not the...
The unit is under warranty. The person you talked to must be new. Find a warranty service center in your area. Take your receipt with you and they should be able to take care of it for you.
Good Day
Dec 13, 2009 | Homelite 'Yard Broom' Leaf Blower
Leaf blower
One suggestion, unscrew the spark plug and reconnect the high voltage wire. In a very dark area move the plug so that the plug thread touches some metal on the engine. Pull the starter cord. If you don't see a spark, remove the two screws on the handle and see if two wires are attached to the Stop Engine Switch. Remove one wire and bend it away from metal and try to see spark when pulling the start cord. If spark occurs, the Switch is shorted and needs replacing.
Oct 31, 2008 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
101 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
