Question about Kenmore 44072 Front Load Washer
When washing heavier items (e.g. small rugs), the machine exits the drain and spin cycle early leaving me with sopping wet items. When I turn the dial to drain/spin, it does the same thing and the items are still not spun out.
    Problem Solver:
  • 5 Answers
This happens to me sometimes....it's generally resolved when I hit the extra spin and just run the whole cycle again.
Posted on Nov 22, 2009
Maytag quiet series 100
Drain it all the way and lay it down so that you can see the drive pulleys and belt, inspect for wear and debris. Clean and if needed replace
Feb 17, 2014 | Washing Machines
Frigidaire front load washer. water is not draining out during spin cycle leaving the clothes clean but sopping wet.
It sounds like either your drain hose is clogged or the water pump is inop. If you have washed any rugs or material the may come off and clog the pump that could be the problem.
You can remove the lower front cover ( 2 screws I think) and follow the black rubber hose to where the pump is located on the lower right side when facing the washer. The hose has a spring clamp you can remove if necessary to clean the hose.
Remember to unplug the washer when working on it.
Aug 09, 2010 | Frigidaire ATF6000ES Front Load Washer
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
I often have a load of towels or sheets that do not spin the water out. They are sopping wet. I make sure not to put to many in at a time still have problem???????????????????????
Are all of your wash items coming out sopping wet? If so, you may have an issue with the spin phase of the wash cycle. Contact an appliance service company.
Feb 24, 2010 | GE WSXH208A Front Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a kenmore front load washer model 41744052500 the other day i did a load of wash and when i went to the drain cycle it worked fine but whenit went to spin it went right a couple of times then left...
tub was out of balance remove some of the heavier clothing and re spin! and in the future donlt try to run so much through it that are heavier items when they are wet
Jan 12, 2010 | Kenmore Energy Star 44092 Front Load...
How do you wash one rug? I can't get the machine
You dont say how big this rug is, but I am guessing its not big enough to spreadevenly around the machine. The machine senses an imbalance and willo not spin or failos to spin at a rate that would rekove the water. Try adding some balance to the drum with another object that will evenly spread the load to see if that helops to get rid of the sopping water.
BTW any pictures of you whipping the rug around in the backyard? That should make for Utube fame!
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
After a wash cycle, the letters UE appeared in the timer window..
UE = Unbalance error.
try to use a low spin speed with loads like rugs, and try to get as even a load as possible. (ie: not just one rug) Don't wash rubber backed rugs, as the backing can break up and clog your machine.
Now, if you are successful washing with the lowest spin speed, you can hold the " Spin Speed " button in while pressing on the power button. Release power button. Now release the spin speed button. Now, press the spin speed button until the next higher spin speed from your last successful spin. Press start. Your washer should now pump out and attempt to reach the new spin speed, without adding any water. (usually about a 14 minute pump and spin cycle) Don't expect to be able to spin out rugs at a high spin speed.
Jul 05, 2009 | LG WM2487H Front Load Washer
Spin cycle
the machine has sensors within it that detect off balance loads, very possible that the 1 or 2 items are not enough to correctly balance themselves, so the machine will never achieve full speed spin.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 44072 Front Load Washer Logo
166 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
