Question about Intertherm P3RA-048K Air Conditioner
Intertherm gas furnace model number m6bb070abfc01
To whom it may concern, I have a intertherm furnace gas powered hot air and it has a pilot light but does not respond to thermostat settings not even fan setting BUT if I got into the unit and hit fan switch for air circulation the fan does go on BUT not from the thermostat. It was working untill; morning yesterday. I open ed thermostat and moved temp up to ninety and watched fopr a flash from the mercury switch and there was none. I opened the control box inside the furnace and saw two relays or apparently relays in appearence.
I can be reached at yankees_out_west@comcast.net or (575) 373 9289
  • 1,420 Answers
Sounds like there is no signal from the thermostat. Take a jumper wire and place it on the R and W terminals in your furnace. Make sure that the door switch is taped down. This should start he burner. If it does, start looking for a blown fuse, bad transformer, bad thermostat or a break in the thermostat wire.
Then take that same jumper and jump out the red and white wires leading to your thermostat. This may help to rule out the thermostat.
Posted on Dec 26, 2007
    Problem Solver:
  • 12 Answers
Check for a open limit switch caused by a dirty filter or poor air flow
Intertherm gas furnace in mobile home..igniter comes on then nothing tries to fire byrners but nothing
by igniter I assume you mean the thermocoupler. are you turning the control button to run after you light the pilot light? Normally when those furnaces quit it is the thermocoupler that has quit. Get a new one and leave it in the furnace compartment as a spare.
Jan 06, 2015 | Intertherm Heating & Cooling
Intertherm/nordyne furnace (24 years old)
Shut off power, get a small wrench, remove orifice spuds and clean them with toothpick. Take burners out and clean rust from them. Check and see if you are getting 24 volts to gas valve. If not replace it.
Feb 15, 2014 | Intertherm P3RA-048K Air Conditioner
Intertherm furnace M1BG wont fire
Make sure the gas valve is turned to the ON position after you had it in PILOT position. Also check the thermostat low voltage wiring @ furnace...jumper the Red & White wires to bypass the thermostat temporarily. Make sure there is 24 volts on you low voltage circuit.
Dec 16, 2013 | Intertherm P3RA-048K Air Conditioner
The wind keeps on blowing out pilot light in the Intertherm Gas Furnace
The wind is probably not the culprit here. You probably have a crack in the heat exchanger, which allows the air from the blower to escape and blow out the pilot light.
Oct 31, 2013 | Intertherm P3RA-048K Air Conditioner
How do I light an Intertherm furnace Model Number MG 068A?
Hello, if the Furnace is a standing pilot then turn the knob on the gas valve to pilot, you will hear a hissing sound then use a match or a lighter to light it at the thermoouple. Hold the knob on pilot for about 30 seconds and then turn the knob to gas and burners should ignite.
Nov 11, 2011 | Heating & Cooling
When I turn on my furance or ac the blower is always on even though the fan is set to auto. When it is on heat it never gives off any hot air, so it never warms up the house. I had someone look at it and...
If this is a mobile home furnace they usually have a two stage gas valve. Generally they just have a delay in opening fully and are convertable from L.P to natural gas or vice versa. It is a possibilty that the gas valve is bad. If so it will have to be replaced. First I would have someone check your thermostat to see if that is what is causeing the blower to run . does the burner ever light? I wouldsuggest that you hire a service tech. who is knowledgable on intertherm furnaces. I don't recommend anyone who is not trained to change gas valves,because of safty concerns. I hope this helps you some. Thanks
Nov 12, 2010 | Intertherm Heating & Cooling
Intertherm furnace pilot won't light
if there are two wires to gas valve check voltage between these two wires while the furnace is going through a start up if you never get a call or voltage to valve your control board is bad, if you are getting voltage ,your valve is bad
Sep 29, 2009 | Intertherm P3RA-048K Air Conditioner
Furnace blowing cold air
Hello , I think I can help , It sounds like the gas valve as long as your sure there is plenty of gas going to the unit and you have an electronic ignitor , if there is a pilot light its not electronic. the gas valve should come as an assembly to install and its pretty easy to complete. Let me know if you need more help. Good luck
Dec 22, 2008 | Intertherm P3RA-048K Air Conditioner
My gas furnace that came with the Mobile Home I just purchased will not ignite the Pilot Lite. All valves from tank open, followed instructions. No Spark
Try lighting all other gas appliances first. On a new setup air in the lines between the tank and the furnace takes time to bleed out before the gas reaches the pilot light.
Nov 21, 2008 | Intertherm Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
255 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
