Question about LG 24 in. LDS 5811 Built-in Dishwasher
LG LDS5811 top rack not cleaning
Has anyone exprienced a problem with the top rack not cleaning, there does not appear to be a clog anywhere, and yet, can't figure it out.
My Lg dishwasher will not pump out the last cycle rinse water. The drying cycle goes ahead and i'm left with dry dishes but a pool of water in the bottom of the washer.
Posted on Nov 15, 2009
    Problem Solver:
I Have the same issue, it sounds like the arms try and start up 4 times then each time power back down, the top arm is not spinning at all. On the fifth time a I hear grinding and then the mid and lower arms spin, soap streaks down the door, nothing stuck in any of the arms, 16 months old, 750.00 out of pocket for junk!
Posted on Oct 28, 2009
I have an LG LDF7932ST Dishwasher and the dishes are not cleaning, especially on the top Rack. I did some troubleshooting and here are the results:
The unit has what is called a 3-way valve and is operated by a solenoid, depending on the age of the unit LG can let you know the part number for you to order this valve.
Mar 02, 2018 | LG Dishwashers
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
Apr 14, 2016 | GE Dishwashers
LG LDF6810ST dishwasher won't clean and spin arms properly
Check for a worn bushing washer on the lower arm. Also, make sure the arms are clean inside - they are propelled by reaction from the water jets spraying out, and clogs will prevent proper water flow through the jet orifices. Sometimes food debris will get through the pump and cause this problem. The diverter valve may also have trash inside clogging it and keeping from seating properly - this could account for both low pressure at the spray arm and water coming out of the lower rack when it should not.
Dec 02, 2013 | LG Dishwashers
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
Mar 15, 2012 | Kenmore Dishwashers
The washer was working good then stopped washing the top rack. pulled the pump cover off and cleaned it now it wont fill with water if i put water in it it drains the water out help me
the top spray arms would be clogged for the top rack not to be cleaning but now it sounds like the main pcb/computer has sizzled and needs to be replaced
Jan 11, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
Quiet partner 1 top rack does not get clean at all
I would suspect you have debris in the pump that is causing a pressure drop so the water is not spraying well in the upper arm.
Try this procedure to clean out the sump. Let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Apr 24, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
Not cleaning on top rack. Pump, fill tube asm. & spray clean. Has any seen if this issue could be the deverter motor in the pump or the control board?
Just to review, the LG dishwasher family, including the LDS5811 has the Verio motor and the check valve that diverts water from the bottom rack to the top rack.
If the valve is blocked/jammed, this would cause the symptom you describe. The valve is visible from inside the DW after you open it up.
It is also possible that this motor has failed.
Apr 20, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Washer arm not working
If your dishes are getting clean, then your problem is a "feture" not a failure. The LG LDS5811 has a Verio motor/check valve that switches between cleaning the upper dishes and then the lower. Depending on when you open the door, one arm will not be spinning.
All the presure is routed either to the lower or upper arm, so it really does help - especially with a water conserving model like the 5811.
Good Luck!
Mar 06, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Heater not working in cycle. No Error Code present
The LG 5811 dishwasher would display the error "tE" if the thermistor has failed. Not seeing an error could mean that the controller card (PCB) has failed. Hard to tell if the heating element has failed or wiring has shorted.
To look a little further, you can see (but not remove) the heating element by removing the filter in the sump area beneath the bottom rack. Disconnect dishwasher from power first and inspect for obvious failure of element.
Gaining access to the heating element is very complicated on the LG units. You have to drop the entire sump unit after turning the dishwasher over on its top.
Recommend a service call.
Feb 10, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
Not reached to the normal
water level in spite
of 10 min. water supply
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low.
(below 10 psi)
Inlet Valve is OK?
The filter of Inlet Valve is clogged
by impure water.
The Hall sensor is OK?
The Impeller of Air Guide is bound
Solutions:
Take action on Water Supply
device.
Measure the electric resistance of
Inlet Valve. (950-1300 )
Clean the filter of Inlet Valve.
Check the frequency of Inlet Water
by the Test Mode.
Replace the Air Braker
Aug 20, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 24 in. LDS 5811 Built-in Dishwasher Logo
385 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
