Question about Freezers
Samsung rs21dpsm How do I change the filter in my samsung rs21dpsm. The light on the front panel is orange, indicating it needs changing, but I don't know where it is.
  • Anonymous Mar 20, 2014
    The fridge stopped coolind both sides freeze and refrigerator the light is on but no degree showing it was after we had the electricity off for 20mn please help its ref RS21DPSW thank you
  • 417 Answers
It may be that the air vent is blocked by something as well but the filter is usually behind the air grills.
Thanks J
Posted on Feb 16, 2008
My frezzer got a orange light I turn off by mistake I do I put it back on ?
by turning it off you reset it. orange light means that one of your filters need to be changed, it is bull s h i t they want you to change filters every 30 days . 168, 12 oz glasses of water is 16 gallons on water is your filter bad NO i change filters once a year.
Feb 18, 2018 | Freezers
After replacing filter, how long before filter light goes off?
Filter indicator : The filter Indicator will be Red when you have used your water filter for 6 months, Reset the indicator (it will be Blue) after replacing the filter by holding the "Alarm/Hold 3 sec for Filter Reset" button for 3 seconds.
The above is how to reset the indicator
Jan 22, 2016 | Samsung RF4267HARS 27 cu.ft. French Door...
My Samsung RS21DPSM is not freezing, the fridge is working and the fan in the fridge is not loud. The freezer is not freezing.
Check the condenser fan in the compressor department. The fan motor is know to fail. The refrigerator and freezer temps will be cool but not cold. I would start there.
Apr 02, 2014 | Freezers
How do I change the water filter for the refrigerator, Samaung RF323TE
Page 13 of the User Manual explains where and how to change the water filter RF323TE User Manual
Click link below for instructions
Where Is The Water Filter And How Do I Install It on my French Door or Side-By-Side Refrigerator?
Or click HERE If you have questions or trouble navigating the Samsung site please ask questions and I will try to assist you, Thanks Sea Breeze
Mar 31, 2013 | Samsung RF323TE 31.6 cu. ft. French Door...
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
Filter changed but still 1% on display panel
Is this a side by side fridge freezer? Most Whirlpool models with LCD display on front- reset filter indicator to display 99% by pressing and holding 'OK' button until filter resets to 99%. If you have a different model, or of this doesn't work, advise on model number and I can instruct further
Aug 10, 2009 | Whirlpool Freezers
I have a Samsung RS21DPSM side by side fridge under 2 years old and the other day a loud noise was coming from fridge Sounds like a fan as when you open fridge door it grinds to a stop) compartment and...
i had the same problem with mine,and fixed it very easily in about 10 minutes all you do is take all the shelves and draws out, then remove the light cover (one screw at the top)then the bulbs,there are three screws on this panel top middel and bottom,take these out,now gently pull the panel off,behind are two plugs unplug these and completly remove the panel.
next unscrew the water chiller at the bottom of the fridge and lay it in the botttom,take the deoderizer cartreges out and remove the two screws out from behind there,just two more screws at the bottom of the panel,there should be two plugs at the top of the panel,unplug these and remove the panel completley ,if like me you should find the fan all iced up, some warm water on a spunge should remove this and the fan should move freely if the ice is severe then remove the fan motor and run the panel under some hot water untill the ice is gone,assuming the motor is'nt burnt out this should cure it.if you want to test it plug the panel back in also the light panel ,and hold the light switch after about 30 seconds to a minute the fan should run,now just put it back together and thats it....
hope this helps
Apr 23, 2009 | Freezers
Samsung water filter rs21 dcns
Hold down the "ice type" and "child lock" buttons (bottom button on the left and the right) together for about three seconds. The light will change back to green.
Aug 06, 2008 | Freezers
Philips whirlpool AFG 027 freezer
The orange button is the "turbo boost" - for reduzing the temperature the fast way. Mostly used when first time use or you put in a lot of unfrozen things at once. When reaching optimal temperture it goes off automatically. The red one is the alert button. Not sure about the green one. Under normal conditions none of the lights is on.
Apr 02, 2008 | Freezers
Freezers Logo
253 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
