Toshiba TP43H60
Unable to adjust red/blue left or right but up/down works
The colors look pretty good but there is a slight halo of green(There is no bowing)
On the menu it looks like the blue is "smudged"
What resistors/fuses should I check?
Is there a free service manual for this?
Have you tried to adjust in the customer menu or in the TECH menu? I can tell you how to get into the tech menu--if it will not adjust there you have a convergence circuit problem and I can tell you what is needed to repair the set.
SD TECH
Testimonial: "Thanks for the reply I have gone into the convergence menu (Is that the customer menu?) I have not tried the TECH menu - How do you get into it?"
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Toshiba
entry to adjust
With the
set on press MUTE on the remote.
Then press
and HOLD mute for several seconds and while still holding it on the remote
press Menu on the front of the set.
A (S)
should appear in the upper right corner of the screen. (It means you are
in the Service mode)
Press menu
again on the front of the set
7 on the
remote will call up the convergence grid
3 on the
remote will change the color to adjust from red to green to blue(do not adjust
GREEN)
You
navigate the grid with 2, 4, 6, and 8 buttons.
To stop the
cursor from blinking so you can adjust at any point use the 5 button—to move
again use the 5 button.
When you
finish you exit by hitting 7 on the remote again.
Sometimes
you have to try a few times to get into the menu—I have had my problems but
once in it is easy.
