Question about Garden
The power washer leaks fro the base when pressure is applied. I removed the bottom housing and the round gasket that houses the bearing is badly damaged. I would like to obtain a repair manual and possibly order some parts. email odonnellpcod@aol.com
osborne382
  • 306 Answers
SOURCE: Noise during high speed spin cycle
sounds like the bearings need replaced, when replacing bearings you need to replace all of them to ensure proper function and life longevity.
Posted on Dec 11, 2007
  • 7 Answers
SOURCE: Motorola A1200 Flip Damaged
Your in luck! www.cnn.cn you can get full housings and replacement hinge springs for this model phone. Im not sure which parts exactly are broken on yours, but you can get any of the case pieces from that web site. I personally have ordered from there before and have been satisfied.
As far as the repair manual, no, there are none available to consumers that im aware of.
Need anymore help let me know!
Posted on Jan 27, 2008
Coldcut
  • 1554 Answers
SOURCE: karcher pressure washer leaking oil
all 4 stroke engines have oil, and 2 stroke can have a oil mixer reservoir to mix with engine gas or to lube the chains , gears, pumps.
If yours is 4 stroke as likely then the oil may be leaking at the seals to the main. (bad news)
Pressure wash it (lol) and locate the leak,
to speed up the leak you can pump some compressed air into the engine (be creative)
Posted on Apr 13, 2008
SOURCE: BOSCH WASHER REPLACEMENT PART
I have the same problem. Bosch no longer stocks the replacement for my particular washer which has the same model no but could be a different fd #. I now have the wrong part as directed by bosch which doesnt have the hose connection. I am not sure what to do with the hose leading to nowhere. Bosch is living off of an undeserved good reputation.
In the present, the reputation is not deserved. Bosch products should only be recommended to enemies. The company and the especially the customer service is beyond deplorable. I hate these appliances. I feel ripped off! The part by the way, which is wrong, is 100.00 with tax.
Posted on Jun 05, 2008
SOURCE: Leaking power washer hose
most auto stores have high pressure connectors and or machines
to make these connections. Also there are radiant heat connectors
that may or may not fit.
Posted on Jul 26, 2008
Replace the roller bearing on mantisworm shaft
I posted this same procedure in a reply to this post:
http://www.fixya.com/support/t2127031-tine_shaft_removal_mantis_2_cycle_tiller
Follow the procedure for removing the worm gear shaft by removing the retaining ring at the bottom of the housing and extracting the worm shaft and other associated parts, Adding heat to the bottom of the housing to expand the hole will help the removal of the #458 roller bearing - with the housing in a vise, tap on the top of the worm shaft through the top hole of the housing with a punch or rod smaller than 1/2" in diameter. Then remove all grease from the housing - to eliminate the remaining roller bearing pieces that may reside in that grease. After total teardown and cleaning place the worm gear housing in a vise apply heat with a propane torch to the outside of the worm gear housing in the vicinity of the beaing location. Applying heat to this area will make the housing expand and make it easier to remove the remnants of the old bearing. With the housing still hot, take a punch or piece of 1/4" steel rod and insert it from the top hole, where the drive shaft goes in, there is a large ridge in the cast housing that the bearing mates against and immediately past that the bearing body will protrude just a little more into the cavity, with the rod against the bearing body gently and rapidly tap on the rod. You can look into the other side through the housing cover opening to be sure you are on the bearing and not the cast metal ridge. I just replaced that bearing this morning, be careful putting the new one in as well, they can be damaged very easily if you don't apply even pressure.
May 17, 2014 | Mantis 2-Cycle Tiller
2004 Ford Explorer V6 engine over heating i replaced gasket, thermostat, top housing unit and the o-ring now it is leaking from behind the base where the thermostat housing is bolted down to just behind...
There is a gasket on the base of the housing, the housing you speak off has the sensor and a heater hose and bolts to top of the intake and also hold the thermostant, this housing does contain a rubber molded gaske, i have replaced a few of these, heres the problem i have run into a couple where the plastic was eaten away in the area that holds the gasket in place. if you remove it you will see a groove that the gasket sits inside of, if the groove is broken then replace the housing but if its good then all you need is the gasket, you will need to ask for thermostat housing gasket to engine intake, this gets confusing to a parts person as they may think you are asking for the thermostat gasket, also in the rear bottom of the housing theres a hose connected to the housing make sure thats not your leak, the hose may also be leaking. good day
Sep 03, 2011 | Ford Explorer Cars & Trucks
Water leaking out of the bottom of the pump - low pressure leak, light stream
Will be a gasket, o-ring or seal that has blown. Could even have a cracked fitting or a split hose.... remove housing where leak is coming from and inspect. call service part agent and order new part (make sure you grease seal or o-ring with rubber grease. If it is a gasket you may need to use a gasket sealant and find out what the torque setting are for the component you have disassembled.
General quide is: 10mm head = 10 - 12 newton meters 12mm Head = 18-20 newton meters
Hope this helps... hard to diagnose accurately with your vague description
Feb 10, 2011 | Karcher 2500 PSI Pressure Washer
Donde esta el termostato del 300 1999 chrysler
3.2L & 3.5L Engines
  1. Disconnect negative cable
  2. Drain cooling system.
  3. Raise vehicle on hoist.
  4. Disconnect electrical connectors from engine oil and power steering pressure switches.
  5. Disconnect radiator and heater hoses from thermostat housing.
  6. Remove thermostat housing bolts.
  7. Remove housing, thermostat, and gasket.
To install:
  1. Position gasket on thermostat and housing.
  2. Install thermostat housing, gasket and mounting bolts onto block. Tighten attaching bolts to 105 inch lbs. (12 Nm).
  3. Install radiator hose.
  4. Install bypass hose.
  5. Connect electrical connectors from engine oil and power steering pressure switches.
  6. Connect negative cable.
  7. Fill cooling system.
  8. Inspect for leaks.
  9. Lower vehicle on hoist.
Jan 23, 2011 | 1999 Chrysler 300M
I replaced my Whirlpool Ultraease Undersink Filtration filter model WHEEDF and th Filter 1 of the pair of filters leaks. I have applied teflon tape to the threaded pin of the mounting unit and the leaks...
I would shut water off and relieve pressure. Remove filter houseing and inspect rubber gasket on bath sides, clean it off and clean inside of cap where gasket sets and on top of housing. Make sure there are no rough spot on either surface. If there are you can smooth them out by using fine grit sandpaper,no coarser then 120 grit. Wipe all surfaces clean and apply 5-6 wraps of teflon tape on threads on filter housing. Before you put gasket back in place you can put a light coating of petroleum jelly,vaseiline or similar,on both sides of gasket. wipe off excess. Reinstall filter and housing. tighten securely. Turn water back on and check for leaks. If it still leaks you can tighten a little more. If it still leaks I would replace gasket. Hope this helps.Thanks
Nov 14, 2010 | Culligan Under Sink Water Filter
Remove thermostat
300M, Concorde, Intrepid, LHS, 1998-2004
THERMOSTAT - Removal & Installation
2.7L Engine
  1. Disconnect negative cable.
    CAUTION Do not remove pressure cap with the system hot and under pressure because serious burns from coolant can occur.
  3. Remove radiator lower hose from thermostat housing.
  4. Remove nuts from heater tube flange studs.
  5. Loosen starter bolt at heater tube bracket.
  6. Pull heater tube out of thermostat housing and position out of the way.
  7. Remove bolt and two studs.
  8. Remove thermostat housing, O-ring and thermostat.
  9. Remove thermostat housing bolts.
To install:
  1. Clean gasket sealing surfaces.
    NOTE Install thermostat with the bleed valve located at the 12 o'clock position, between tabs on seal.
  2. Install thermostat and seal into thermostat housing .
  3. If removed, install two studs.
  4. Install thermostat, thermostat housing and O-ring and bolt. Tighten attaching bolts to 105 inch lbs.(12 Nm).
  5. Lubricate new heater return tube O-ring with coolant.
  6. Position heater return tube flange over two studs. Install nuts.
  7. Tighten retaining nuts to 53 inch lbs.(6 Nm).
  8. Tighten starter bolt to 40 ft. lbs. (54.3 Nm).
  9. Connect the lower radiator hose to the thermostat housing. Install hose clamps.
  10. Refill cooling system.
  11. Inspect for leaks.
  12. Connect negative cable.
3.2L & 3.5L Engines
    NOTE The OEM thermostat is staked in place at the factory. To ensure proper seating of replacement thermostat, carefully remove the bulged metal from the thermostat housing using a suitable hand held grinder. It is not necessary to restake the replacement thermostat into the thermostat housing.
To install:
Hope this help (remember comment and rated this).
Apr 04, 2010 | 2000 Chrysler Concorde
What is the easiest way to change a thermostat?
Hello there:
this is verry easy to do, make sure to get some gasket adhesive
(1) remove the radiator cap
(2) losen the radiator hose at the engine side (this is where the
thermostat is located this will help drain the water out.
(3) remove the hose from the thermostat housing.
(4) remove the thermostat housing and you will see
the thermostat, do not forget the way that it is installed.+
(5) remove the old thermostat and remove all of gasket
that is stuck to the surfaces.
(6) apply the gasket adhesive to the housing surface and
install the gasket and the thermostat.
(7) apply a medium size bead of gasket adhesive to the other housing part and install
it and tighten it down and reinstall the hose.
(8) refill the radiator with water and start the vehical let run for 15 min and check for leaks tighten nuts if needed but not too much
or you will break the bolt ok if no leaks CONGRAT'S
hope that this has helped out a lot please rate this for me ok?
best regards mike
Aug 05, 2009 | 2003 Jeep Grand Cherokee
2003 yz impeller seal is leaking, do i need to replaice head gaskets thanks ian
I am not sure what you mean by impeller seal so here are a few scenarios:
**Note: Based on YZ250. others may be similar.
-If the gasket around the impeller housing is leaking you can replace that on its own. Open rad cap, drain the coolant using the lower screw with the copper washer behind it. Then remove the other 3 bolts, remove cover, clean mating surface, install new gasket, snug everything up, and replace the coolant.
You don't need to replace the head gaskets unless your leaking from there, or getting coolant in the engine.
The same would apply to your base gasket.
just in case:
-if your transmission/gear oil is milky, your will have to change the oil seals on the impeller shaft.
Jul 17, 2009 | 2003 Yamaha YZ 250
How to remove carbeurator on honda gx 390
remove the wing nut on top of the air filter housing. remove housing. remove next wing nut over air filter. remove air filter and bottom of housing. next, remove the 2 nuts on those threaded bolts you saw. there is one more bolt that you must remove located between the air filter and the exhaust. now the carb can be removed. this is possibly going to be very difficult but trust me, it can, and must be done. the carb should slide off of those bolts once you break it free from the intake. get your pry bars ready but try not to break any of those plastic parts! good luck.
Jan 17, 2009 | Honda Pressure Washer PSI 3000
Oil leaks from the oil filter adapter
If it is not the suggested gasket that is leaking then it is the oil pressure switch located exactly above the oil filter adapter. The black plastic housing could have developed a crack and oil will ooze downward and drip off the bottom of the adapter. I had this problem and changing the oil pressure switch took care of it.
Dec 17, 2008 | 1993 Honda Accord
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
