Question about Dryers
Dryer heats up and is getting power, but the door
Electric Dryer heats up and is getting power, but the door switch is not getting power and dryer does not tumble.
    President:
  • 1,304 Answers
Door switch is fine or it would not heat or do anything
more than likely its a bad belt
Posted on Oct 08, 2009
Cabrio dryer has power from plug but can't get it to start?
If it is an electric heat dryer, a blown thermal fuse will stop it from operating at all. The door switch can keep a dryer from tumbling... but a common problem on these new computer controlled heaps of junk is a bad solder joint on the back of the computer board.
Oct 11, 2016 | Dryers
Whirlpool wed5300sqo has power but will not start switch has continuity
Possible causes 101:
On all dryers, the door switch allows the dryer to start tumbling only when the door is closed. If the dryer does not start when the door is closed then the door switch may be defective. In most brands of dryers, the switch is located behind the front panel with the switch button protruding into the door opening. The switch and can be tested with a multi-tester for continuity and it may have two or more terminals. The test should be made between the terminals marked "C" and "NO" and should read "0" ohms when the door is closed or the button is depressed
The thermal fuse is a safety device found in some dryers to prevent overheating. It is a heat sensitive fuse and will open if the temperature becomes too hot and will typically interrupt power to the drive motor and cause the dryer to be inoperable. The thermal fuse is about an inch or more long and normally embedded in a white plastic housing. Some brands of dryers use more than one thermal fuse, and they are normally located on the blower housing and/ or the heating element housing in an electric dryer and/or the burner housing on a gas dryer. The fuse will not have any continuity when tested with a multi-meter. Disconnect power to the dryer before testing the fuse
Oct 07, 2016 | Whirlpool Dryers
White knight 44aw not spinning and no heat
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 26, 2009 | Dryers
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Valh my dryer model fer641fso wont start when i push the start button it does this low beeping sound bought brand new only owned for 5 months worked fine all day yesterday stopped working last night.
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly. OR The start capacitor may have failed and i would not suggest you deal with that as they give out a nasty electrical charge, also check and clean all filters and check your user manual for further advice as your machine should still be under warranty, call the numbers listed in your manual. good luck
Jul 19, 2009 | Frigidaire Electric Dryer
The power turns on, and clicks, but will not tumble
If it trys to heat up and does not rotate, probably a bad motor. If it does not heat up and does not rotate probably bad timer or bad door switch.
Mar 13, 2009 | Whirlpool LEQ9858P Electric Dryer
Won't run
If "won't run" meaning; "does not tumble/spin" this can be a couple things;
1. Defective Drive Belt (Likely): Broken or jammed (not properly attached to motor/pulley). Nothing will happen when pressing start; unit will not heat or rotate/tumble. "Normal ware and tear"
2. Defective Door Switch (Very likely) - Very common due to constant "slamming" of door. The door switch enables power to be passed through-out machine when door closes for safety purposes. Switch located at door area and can be tested for continuity. "Nothing will happen when pressing start; unit will not heat or tumble/turn". * Fairly easy to replace; two mounting screws.
3. Defective/Jammed Motor (Rare, but possible): You may hear a "humming noise" and burning smell. Also, excessive lint in blower housing may jam the motor from rotating. "Does not come on; does not tumble/turn"
Remember to disconnect power from unit before servicing.
Jan 27, 2009 | Kenmore 659 Electric Dryer
Electric dryer not spinning
Well first of all you may check out the Door Switch if it's defective then your dryer is not able to spin, it may interfere with your dryer drum's ability to tumble. Test your dryer's door switch. If it is no longer functioning than you need to replace it. you need a multimeter to check it. Post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Dec 04, 2008 | Dryers
This is the 2nd time my dryer in 1 year just stopped working and last time it cost me $100
http://www.repairclinic.com/0088_8_1.asp#Level1_1
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
There's no heat If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Frigidaire Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
