Question about GE Dishwashers
Control stuck on, with multiple light combinations
When you lock the door all the lights on the control panel comeon, then the control lights go off and the status lights will showmultiple different combinations: ''sensing, sensing and washing, washingand drying and sanitized'' all at once. And this just goes on and on. Pressing Start/Reset appears to start another cycle, but doesn't seemto end one. There was a small amount of water in the bottom (along witha drinking straw), but I think this was because it was mid-cycle. Atdifferent times I could hear water draining out into the disposal.
    Problem Solver:
  • 5 Answers
All this is normal except for the lights coming on. could be the panel control board.
Posted on Oct 08, 2009
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
No dome lights or door combination lock entry
it could be a gem module problem that controls dome lights and door combination control
Aug 21, 2014 | Cars & Trucks
Oven lock motor frigidaire stove close and open continuously- flashing door lock light
Hi Chris -- if I am understanding you correctly, your door lock is stuck with the door open. If this is the case, locate the oven door light switch that is typically in the top left corner of the unit. Press and hold the switch button in for about 30-60 seconds. While you're doing so, look for a flashing light on the control panel next to the word, "lock". If the latch hook is in the locked position, continue holding the button and press the CLEAR/OFF key on the control panel. Hold the button in until the flashing light goes off. If this does not resolve the issue, please supply your unit's model number and any additional symptoms it was experiencing prior to this event so that I can be of more assistance to you. - Best of Luck!
Aug 27, 2012 | Frigidaire Ovens
ABS Light comes on, speedometer stops working and locks switch
I will bet the check engine light comes on as well?
Jul 05, 2017 | 2003 GMC Yukon XL
Control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
May 25, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Dishwasher not running
Check door lock, if sensor in there is stuck the machine won't operate
Check also the water level sensor, if it is stuck the cycle wont start.
If the machine is still stuck then it is probably a faulty timer control board.
Before replacing the control board , the inlet valve, impeller, wiring harness, and additional electronic controls must be tested.
Try also unplugging the appliance from main, or tripping circuit breaker to cut power for ten minutes. ~This may unlock a jammed control board.
May 21, 2009 | KitchenAid KUDK01TK - Multiple Color...
Washer is stuck on control locked
Press & hold 'end of cycle' at right of panel for 3 seconds. The light will come off.
And rate me plz....................
Mar 27, 2009 | Whirlpool GHW9100L Front Load Washer
Lock on light flashing
I finally decided to calm down and use my head and managed to solve the problem. I read the instructions that are on the top of the dishwasher door. ( Smart move on my part HUH!) It said that when the door lock light is on everything is disabled. Hold the air/dry button down for 4 seconds and the lock light will go out. Guess what, IT WORKED. Here is what I learned from this. Always read all instructions. I spent $9.95 for an answer that was right in front of me. Humans can be so dumb I am!!!!
Jan 28, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
153 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
