Question about Olympus FE-210 Digital Camera
I was shooting with my camera and it was working fine when I opened the battery door by mistake and the batteries fell out. After replacing the batteries I keep getting battery empty on my screen and can't use the camera. Help mister wizard!!!!!!!!!!!!! Marc
  • mbc9 Oct 08, 2009
    Duh,
    I've tried many batteries before but now it's working.
    Thanks,
    Marc
    This is a new camera to me how do you look at pictures taken and delete?
    Brigadier General:
  • 3,614 Answers
Hi, Did you try to recharge it again? If those was done and got the same error a possible problem on the battery, a damged on the cell battery that make the pack not to hold any charge into it... Did you try to use another battery pack?
Posted on Oct 08, 2009
Empire Comfort Systems fireplace remote control not working since fell off table. Fireplace still works fine manually and the batteries in both the remote control and receiver were fine before it fell. ...
I assume you've tried removing and re-seating the batteries in the remote. If this doesn't reset the remote the fall most likely broke a component or solder point on the circuit board. If all else fails you can try opening the remote and making sure no wires are broken. Look closely around the battery contact points. Often when a remote is dropped the weight of the battery can cause damage to that area.
May 02, 2015 | Home Security
Battery door metall batterry connectors fell out
When you can't close the battery door as it should be closed, you can't turn on the camera. In almost all digital cameras there is a protection switch, that prevents the camera to work, with an open battery door, because the camera could stop any moment when the battery comes loose. When the camera was accessing the memory, when it falls without power, the memory can be damaged and you could loose all the pictures saved on the memory card.
I'm afraid, when the battery door came out, some things are missing, like a spring, axel and perhaps some other little metal or plastic things. To come out, some mechanical damage must be there, so it won't be easy to reinstall the door yourself.
Bet thing you can do is show it in a service centre and ask if it can be repaired and what it will cost.
Service manuals, with pictures about all parts, are only sold to approved repair centres.
The only chance to find anything, is on ifixit dot com, because they have manuals and videos of lots of electronic stuff for free.
Repair over there is on your own risk.
Jan 17, 2014 | Samsung SL30/ ES15 Digital Camera
I dropped my Nikon D90 (Lens clicking and Battery problem)
No. The warranty does not cover damage caused by dropping it. Maybe you have an insurrance that covers it?
Jun 30, 2010 | Nikon DSLR D90 Digital Camera
I have an old 35mm Canon Sure Shot 70 Zoom. There is film in the camera, but the battery is dead. I can't find the owner's manual and want to know if I'll expose the film if I open the camera to change the...
You don't need to open the camera to change the film. The battery door is on the other end. You open the door by inserting the protrusion on the plastic end piece of the strap into the slot of the battery door. It takes a small 3 volt battery.
Sep 04, 2009 | Canon Sure Shot 70 Zoom Date 35mm Point...
Lens locked in open position after batteries fell out
mine sometimes does that. 1.get a new cheaper camera. 2. use duck tape 2 secure the door.
Jan 26, 2009 | Kodak EasyShare CX4230 Digital Camera
Nikon COOLPIX 3100 Digital Camera
I WOULD SUSPECT THAT THERE IS SOMETHING WRONG ON THIS NEW DOOR THAT THE BATTERIES ARE NOT MAKING GOOD CONTACT WITH THE DOOR AND THEREFORE NOT SUPPLYING POWER TO THE CAMERA. IF IT WORKED BEFORE THE DOOR WAS REPLACED, THERE MUST BE SOMETHING AT THAT POINT. I WOULD LOOK THERE FOR PROPER PRESSURE ON THE BATTERY OR BATTERIES.
Oct 31, 2008 | Nikon COOLPIX Cameras
FE-140 Battery compartment door broken
you could try and put all the info about your camera in to google search..or the same on ebay.
Oct 27, 2017 | Olympus FE-140 Digital Camera
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Battery door error
The switch is soldered to the circuit board. The tab portion of it is what you found after opening the battery door. I believe you would have to buy the entire circuit board to make that repair. Most camera manufacturers sell assemblies rather than small components. It would be possible to take one from another camera of the same type and transfer the switch. It is fairly delicate work.
Jan 08, 2008 | Olympus FE-190 Digital Camera
Lost battery door
Surely you can use a little duct tape or something else to secure the battery in place. You might want to contact the manufacturer to see if they have the part or you can check on ebay under the camera model to see if some parts are also listed. Happens on many occasions..
Sep 23, 2017 | Jazz Jellies 207 35mm Point and Shoot...
Olympus FE-210 Digital Camera Logo
21 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
