Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic Hdtv 1080i pt-43lc14 When I press power the green light starts blinking for about 1 minute then it turns red the lamp light also blinks red. The tv sounds like it wants to work but there is no picture nor sound. the TV makes a little noise but no actual sound coming from the TV. The screen remains black. I was told to order a STK392-110 and solder that in the mother board does that sound right to you? Please help. Thank you, Roland
  • rbedregal Oct 08, 2009
    does that just happen at random I've had the tv for several years. The lamp went out last year but I don't feel like thats the problem this time. do you agree that it isn't the lamp?
    President:
  • Panasonic Master
  • 1,922 Answers
You can try a new regulator, but also check the horiz. output transistor for an emitter to base short, then also suspect the flyback transformer both are located on the deflection board
Posted on Oct 08, 2009
  • 6,826 Answers
I would check under all the boards,for a cold solder joint,conecting a heat sink,to the board.This problem occurs more often than you would think.At the ***,plant the robots that put theses babies together,are not as good as a human.Hope this is some help.let us knoe if this helps.Just clean real good,and re solder the heat sink.
Why is my panasonic hdtv 1080i on off switch blinking red
thats usually an error code. How many times does the light blink?
Apr 02, 2013 | Panasonic PT-53WX53 53" Rear Projection...
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic pt-43lc14 won't turn on
Try checking your lamp door. I have seen a few of these that you need to really wrench that screw down. Let us know.
Mar 22, 2010 | Panasonic PT-43LC14 43" Rear Projection...
I have owned the PT-43LC since Nov. 2005. Up until now, it has been a great HDTV. Today, I had my first "issue" and have yet to discover a fix. I turn the TV on and it blinks green, indicating that the...
That sounds like a bulb. You should pull it out and check it.
Pretty easy to do, but if mine did the same type thing, replaced the lamp and powered right up.
Sep 12, 2009 | Panasonic PT-43LC14 43" Rear Projection...
TV WONT TURN ON
I found the problem with my set! I pulled out the lamp to inspect and low and behold the filiment was burned out. Just ordered a new lamp to replace it. That should fix it.Very easy to pull the lamp .
Dec 11, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Turn on and Power and Lamp Lights blink.
Just because it doesn't look broken doesn't mean it hasn't failed.
Is the TV over 2 years old?
If so, buy just the bulb (not the whole lamp assy) from us at sedonix.com, install it yourself and save about 75% of what Mitsubishi charges.
Dec 13, 2007 | Panasonic PT-43LC14 43" Rear Projection...
PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Nov 27, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
