Question about Pro-Fit Pro.Fit Dg 91 96 Dodge/Plym/Chry Caravan/Voya/T&C 96 00
1991 dodge power ram 150.. no nothing.. spark, fuel, nothing. why
I have a 1991 dodge power ram 150 with a 318, recently had it running n never expierenced any real problems with it. but after sitting for about three to four weeks with no battery in it i bought a new battery n installed it, no the truck is not showing spark...no juice to coil? no juice from coil? n fuel pump does not seem to be pressurizing either... what n where do i start? replaced pickup.... still nothing
  • 7 more comments
  • cebulskig Oct 08, 2009
    ya it turns over, but wont fire... lights r currently out of commission, didnt check the horn.. gauges that worked before still seem to? not sure if that last bit helps...
    checked ground with tester.. seemed good, n connections seem solid
    i have a 1991 dodge power ram 150 with a 318, recently had it running n nevere expierenced any real problems with it. but after sitting for about three to four weeks with no battery in it i bought a new battery n installed it, no the truck is not showing spark... n fuel pump does not seem to be pressurizing either... what n where do i start?
    brake and anti lock brake lights come on n then go off after about ten seconds.. also 4x4 engadged light comes on..but noticed when trying to strt it that the 4x4 engadged light goes on n off.. never noticed it doing that before...
    horn and dash lights work as well as headlight... brake light n anti lock brake lights come on when key is in the run position, but go off after about ten seconds...
    i checked fuses under the dash... they all seem good. r there others somewhere i should check? n yes i took the cap off the distributor, and the rotor is turning, n i replaced the pickup coil... still no luck.
    and i didnt notice any arching when replaceing the battery, the old battery that it had in it was a marine battery, n seemed to no longer hold enough charge to even get the 91 dodge ram to kick over
    no the battery came fully charged.. turns over like a champ, just wont fire... had a few people say i should look at replacing the computer, as that is the only thing that would resolve a sudden fault in fuel pressure being non exsistant as well as no spark... is this true, is it worth looking into, i was hoping that it would be something really easy, n i already replaced a 35 dollar pickup coil for apparently no reason...
    hoping someone could maybe lead me to some alternative ideas, like other fuses somewhere, maybe a rely that might cause both fuel and spark to suddenly dissappear??? this truck ran fine 3-4 weeks ago and then just sat.. replaced the battery because im selling it, n now that i finally sold it, it wont fire... no gas, no fuel... something like the computer? other options that make sense?
  • 1,000 Answers
I would start by checking all the fuses. Was the battery removed because it is old and failed? Any battery arching when the battery was removed or replaced?
I'm assuming the engine does crank over.
When the key is turned to the "run" position, do the instrument lights come on such as the battery light, service engine soon light, oil pressure and so on?
Let me know.
Posted on Oct 08, 2009
    President:
  • 1,714 Answers
Start right at the battery. Re check the connections at the battery posts. Then check the negative wire going to the engine block for the chassis ground. Does the starter motor turn over? Do the headlights work? Horn?
  • Craig Butler
    Craig Butler Oct 08, 2009
    Have you checked all the fuses? There is an ignition fuse in the fuse block. How about the cap and rotor? Have you taken the cap of the distributor and checked in there?
  • 3,051 Answers
Hello there:
If you have a friend that has the handheld diagnostic unit you can hook it up to the onboard computer and have it analysed, or somehow get the truck to a autozone for a free test they will be able to give you any fault codes that will help explain what is going on. also if you can see if you can hear the fuel pump at all it should make some sound if it is working it may just need to be primed or you might have a wire that is loose somewherre or you have a master fuse that has failed probably under the hood in the fuse block refer to the manual for the location of this. ok?
best regards michael
  • 344 Answers
If you bought the battery new they come discharged, I know its simple but often over looked
1986 dodge d150, 318 cu engine Truck starts sometimes, could idle for an hour or longer then just quits, not like a fuel problem quits no sputtering just dies like turning the ignition off. Coil is good...
Check your ballast resistor, they are a major failure item. The ballast resistor lowers the voltage to the coil and uses resistance to do so. Test would be to put battery voltage to positive side of the coil, during the failure condition, but my bet is resistor.
Aug 30, 2011 | 1991 Dodge Ram 150
Got a 1991 dodgeram w150 360 motor need timing chart.
is there ay one out there can get me a fuel diagram for a 1990 dodg ram 150 with a 318 motor cause im tired of seeing that you have to pay for a question
Nov 18, 2010 | 1991 Dodge Ram 150
I recently put headers on my 318 and didn't reattach the o2 sensor because there was no plug on the header. could this be the reason my truck now misses?
Ya you will need to install the 02 sensor ,, you can buy the adaptor threw a place like summit racing and it will need to be welded on to the header.
Jul 15, 2010 | 1991 Dodge Ram 150
How to reset the maintenance requried light on a 1991 dodge d150 --318 engine
take the battery negative cable of the battery for about 10 minutes and then put it back on the battery post
Jun 12, 2010 | 1991 Dodge Ram 150
I have no spark or injector pulse sometimes it
You got a crank sensor at back,on top of bellhousing.
Injector pulse, I believe is controlled by hall effect sensor in distributor, as well as spark
May 16, 2010 | 1991 Dodge Ram 150
Location of crank sensor on a 1991 dodge 318
It is in the top of the transmission bellhousing near where the engine meets the transmission.
Apr 24, 2009 | 1991 Dodge Ram 150
Locate fuel filter
It is located under the cab and attached to the frame
Mar 18, 2009 | 1991 Dodge Ram 150
Pro-Fit Pro.Fit Dg 91 96 Dodge/Plym/Chry Caravan/Voya/T&C 96 00 Logo
438 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
steve morris
steve morris
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
