Question about Hampton Bay 46056 Callaway II Ceiling Fan
Hampton Bay 46056 fan
I have 2 hapton bay fans with remotes. One upstairs and one downstairs. If I turn one of the fans on, the other will turn off. Same for the lights. Can I program them to turn on and off independently?
C
  • Anonymous Jan 06, 2008
    Ditto. But I live in a duplex and the neighbor has the same fan installed!! : )
  • Anonymous May 15, 2009
    We live in a condo and someone else seems to be turning our fan on and off! We tried to take the light fixture down but couldn't find the place to change the code. Any suggestions?
    Problem Solver:
  • 5 Answers
I have three Hampton Bay Ceiling fans with remotes for eight years. I doesn't help when a neighbor buys the same make and model. So, I had to come up with a different code for mine. I had to change the code for the remote and match it with the code in the fan. To change the code in the fan, that depends on the type of fan you have, some you would need to look on top of the fan and use a skinny stick to change the code, other's you would need to take the light fixture down to get to the controller box to change the code. I have both types, this is how know. PS. if ever, which will happen, if the fan doesn't respond to the remote then you would need to replace the controller inside the fan. Here's the warrenty no. 800.749.3267 for replacement.
Posted on Jun 08, 2008
I HAVE A HAPTON BAY 54" SIDEWINDER FAN WHERE CAN I PURCHASE THE REMOTE MODEL #UC7067RYD?
Maria, Try Lowes or Home depot, I believe they carry replacement remotes for Hampton bay.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 15, 2016 | Dryers
Remote does not work. Have relaced remote and receiver. Fan and light turn on and off at any time by themself!!
Change the frequency settings. Your neighbor's fan is probably on the same setting you have now. If you didn't have problems before you put in the new receiver, change to original settings.
Aug 24, 2015 | Hampton Bay 46056 Callaway II Ceiling Fan
Lost manuel and can't get remote to work
These Hampton Bay Remote units are notorious for failing.
I'm sure you've done this , but just in case: Are the batteries good and installed correctly?
Is the wall power on?
If the remote is a standard feature, make sure the fan switches are on. (The remote add-on kit bypasses the switches)
Bring the remote to within inches of the fan and try it.
If it works then, The remote/receiver is combo needs replacement or removal (switch back to manual because the string has a better range.)
Sorry for the bad news, but please don't shoot the messenger.
Mike
Sep 28, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Trying to remove cover that houses the ball and pipe that hangs the fan. There is no screw to hold the ceiling mount cover to the ceiling mount. I tried pushing up and twisting but no luck. Could someone...
There should be a couple of small screws at the very top on the side of the canopy...you will need to loosen these a few turns and then turn the canopy and drop it down...
This link will help you they had the same problem as you...
http://www.askmehelpdesk.com/electrical-lighting/hampton-bay-ceiling-fan-removal-25673.html
heatman101
Apr 29, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Fan goes in reverse instead of pushing air down it goes counter clockwise. How do i reverse it?
1.) this model uses a remote control controller to operate its functions
2.) the reversing is done via that remote.
3.) the link is wireless
4.) do you have the remote?
Apr 28, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Light turns on out of the blue. Even the fan
Sounds like the switch unit inside the fan is being triggered by noise. That could be caused by an abnormal amount of radio or electrical noise in that room/on that electric line. You should inspect the remote unit, see if it has a sensitivity setting, see if the antenna is in a weird situation, and, failing all that, see if you can move the antenna wire to a different position, shorten it a little or wrap part of it in foil, etc.
Oct 13, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
The lights on fan go on at 2am for NO REASON!!
I think I've figured it out. I got in touch with the manufacturer of Hampton Bay Fans, King of Fans. You can call them yourself at 800 283 6513. They said they hear about this problem all of the time. The thing is, if you have more than one HB remote control fan in the house, they can start interfering with each other - even though no one is touching any remotes at the time. Weird, I know. Another thing that happens is if your neighbor has a hampton bay fan on a remote, they may be triggering your fan. Also, apparently garage door openers can activate fans as well. Anyway, the rep said the solution is to get up into the fan base and find a series of four dip switches. Then take the batteries out of your remote and find a set of four switches. Or maybe its a set code. I'll find out tonight when I get home. What you need to do is make sure the combination code you set in the fan matches the code in the remote. She said the majority of the time this eliminates the "haunted fan" problem. If the problem persists, you may need to replace the receiver in the fan. I'm going to try it out tonight.
Jul 20, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Remote control fan hampton bay
Just insalled a hamptonbay fan and everything works except the dimmer. Light comes on on wall switch but remote won't dimm lights
Apr 04, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Remote
If the fan is not responding to the remote. Then it is the controller inside the fan. To order a replacement part contact "King of Fans" who owns the warrenty for Hampton Bay. The number is 800.749.3267 for about 43.00. Hope this helps.
Mar 02, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Hampton Bay 46056 Callaway II Ceiling Fan Logo
250 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
