Question about Garden
Have self propeled craftson 917.377200, I took carborater off and now need to know or see picture of how to reconnect linkage thanks 4.5hp
  • 40 Answers
SOURCE: Lawn mover - self propelled does not work - need to manually push
Take it to a shop. one of your safety switches is most likely defective.
Posted on Apr 27, 2009
  • 7 Answers
SOURCE: yardman push mower self propell not working
check to see if it is belt or gear driven
Posted on May 02, 2009
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
  • 133 Answers
SOURCE: Self propel issue's
I am not sure what the problem is but may be. A couple of things I would do is check and make sure that every thing with the self propel is as it should be like springs not broken or bad connectors. Also I would make sure that all bolts are tight that holds the self propel unit. The first thing I would check is see if all the wheels are at the same height.
If this doesn't help I would go to the Troybuilt web site and see if they have tech support, or see if they have a phone number under contact and call them and talk to some one there.
Good luck. I hope this helps.
roundo4
Posted on Aug 14, 2009
bulldogchief
  • 388 Answers
SOURCE: honda harmony self propelled cable snapped at end
Get a replacement cable, part number should be in your user manual...when you get the cable it should have directions on how to replace.
Posted on Sep 08, 2009
TB210 Drive Engage Cable. Can not remove Front Cover.
Hi Chip, I too have a model 12AGA26E011 which has suddenly stopped being self propelled. I'm looking into how to remove the top cover so I can get to the belt and drive mechanism to determine what is amiss. If i have any luck I will let you know. obviously others that have posted here are stating the obvious but not answering your question. If you happen upon the solution please provide an update. Thanks! Doug
Jul 13, 2013 | Troy Bilt 5.5hp Self Propelled Mower
My self propell lawn mower stop propell
the cable needs tension to engage the belt tensioner
Sep 23, 2012 | Garden
Troy-bilt self-propelled won't engage drive
Make sure the drive belt that turns the wheels is in good working order as well. It may have detached.
May 02, 2012 | Troy Bilt 5.5hp Self Propelled Mower
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Hi - My 4 yr old toro self pace lawnmower suddenly stopped self propelling. any suggestions?
Check the drive belt and linkages/cables
Also the transmission area could have become plugged with grass/debris not allowing linkages to move properly.
Nov 15, 2009 | Toro Lawn Mower With Toro Power Tools
Self Propell Does not work?
The first thing I would check is remove the drive wheels and check to see if they are stripped out. Replace if nec. Also check to see if any linkage is defective, missing or what ever. If it has a belt check it, replace if nec. Once you get the cover off try engaging the self propel and see if things are working like they should.
Good luck
Sep 03, 2009 | Garden
Where and how do you clean the carborater
I would have solved the problem if you were smart enough to spell carburetor.
Jun 16, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Apr 29, 2009 | Garden
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
