the self clean cycle will run for 2-3 hrs and the door will remain locked for another couple hrs while cooling let it finish and wait till the next day basically if it still wont open (sorta common) the door lock assy needs replacing.
I have a Jenn Aire in wall range with convection and conventional oven . When you set the temp for...
(More)
I have a Jenn Aire in wall range with convection and conventional oven . When you set the temp for bake or broil the preheat come on to 100 but the oven never gets hot. The range works perfectly but the oven doesn't work on bake or broil.
I have a Jenn-Air that came with our house. The only information I can get from it is that its...
(More)
I have a Jenn-Air that came with our house. The only information I can get from it is that its Manufacturer ID# is E33658. If I could open the oven door, I could probably find more information, but since we cleaned the oven last night and unlocked the door we still can't open it. Is there a procedure, or some step that I am missing? Thank you in advance.
Bottom heating element burnt out on Christmas day & bought a new element today &...
(More)
Bottom heating element burnt out on Christmas day & bought a new element today & installed it. After installation went to check operation of oven & when you mash the button for the oven to come on the display lights up to set the temperature & it goes to 100 degrees to start like it always has but it doesn't heat up on any setting, not even the broil setting works. Does this unit have a reset button or a sequence to reset it? Any suggestions?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
