Question about Philips DVDR3505/37 DVD Recorder
Tunner don't remember channels
I can auto program the tuners (Both) and after a day or two they are gone.
Disable the auto time set and set DST to OFF
Posted on Mar 25, 2008
My Haier tv says "No Signal" & won't show my channel I did auto scan & it's still blue with a grey box saying "No Signal"
To eliminate if it's the cable problem or not, see if you're able to get a picture and audio on another input by connecting a dvd player as an example. If you're able to receive a picture and audio tehn you know that input works. If you can then try connecting a antenna to the tunner, assumming that you had cable connected prior, and scan the channels again but instead of selecting cable select air then channel scan. If you still are not able to receive channels, then you have a bad tuner. You will need to have the main assembly board AKA scaler board replaced. You could however by-pass the tuner by using a VCR and connect your cable to the tuner on the VCR then use Composite wires from the VCR to the TV composite input and change the chanels from the VCR.
Oct 23, 2013 | Televison & Video
Channel search problem
The mains system memory IC to your TV has damaged. Replace it.
Aug 12, 2012 | Konka K1938U 19" TV
Not getting all the channels provided by the operator in old bpl tv
BPL quatra focus have a tunner which doesnt support S band and Hyper band. If you have to get allmost all channels then you have to upgrade the tuner. Tuner is component inside the TV to wich we attach the antenna or cable. There is no other option other than replacing the tuner. Replace a tuner with S band and Hyper band capability. If you need any more assistance feel free to contact by fixya. Tuner will look like one in the picture wich you will find inside the tv.
Jun 16, 2012 | Televison & Video
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
It does not pickup the digital channels when i scan that my other tvs do for example 2.1, 5.1. i know i have these through my cable since they were picked up by my other tvs
you first must go into your menue then into were it says chanell next go to auto program for the digital tunner then let it run if that does not work then you have tunner problems it would need replaced
Oct 25, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Tv not picture not sound
Is it varying the tuning voltage from 0v - 32v as it searches , if not then jungle/micro is faulty or check between tuner and micro/jungle
May 13, 2009 | Sharp 27C-240 27" TV
Program the hd channels
The FLM-2601 is an 'HD Ready" TV but does not have an HDMI input or a digital tuner, it only has an analog tuner. You will need a cable box or other source to view HD. Using the component inputs (YPbPr) you can get up to 1080i.
Apr 21, 2009 | Polaroid FLM-2601 Television
Samsung Flat Screen SDTV Model #TXN3245FPNXXAA
on what you have explain you are to check with cable provider if your tunner was the problem all the channels would be affected try plugging another tv to the same cable and see what it does if you get the same symtoms then it will be from the cable company.if not then you will have to take your tv to a repairman and have it check probably a component in the tunner circuit is bad.or you tunner will need to be replace. good luck
Mar 26, 2007 | Samsung TXN3245FP 32" TV
Philips DVDR3505/37 DVD Recorder Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
