I can't make the "radio" part of my tuner work. However,I can play a CD ..Any thoughts on connections? Thanks, Darrell.
    Brigadier General:
  • 3,614 Answers
HI,
If you were using a separate deck, it could be the audio wiring was not connected to the system speaker. A possible loose, a problem on the connection or in the wiring itself
Hope this helps
Posted on Oct 08, 2009
New Alpine radio, went through setup, plays fine on radio/tuner on all four speakers, but ipod (USB port) or internal CD only plays on front speakers.
Just a thought - the usb provides a digital signal which carries information about how the signal is to be processed; mono, stereo, surround sound stereo, etc.
If the mp3 music file was only recorded in 2 speaker stereo perhaps that is how it plays back.
Admittedly the radio signal is stereo and yet it plays on four speakers but unless it is a DAB radio it is analogue and maybe that makes a difference.
Perhaps there is an internal electronic fault with the digital processing part of the unit. I suggest reading the handbook again and then perhaps contacting the seller.
Mar 28, 2016 | Alpine Car Audio & Video
My Philips FWC550 automatically keeps switching to a radio station and has volume issues!
You have a bad Rotary Encoder or Display Microprocessor(computer inside your Philips). If you are interested in having it repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Jun 20, 2015 | Philips FWC550 Shelf System
Electrohome ean 0s700 radio wont play
Check the aerial connection. Some FM radio's will mute the static and only pick up strong signals. If it is an FM AM radio check the AM radio. If that is OK and the connection's are good you might have faulty Tuner circuit, which would need a trained technician to look at.
Dec 10, 2014 | Audio Players & Recorders
No sound from the cd and extended media but have sound from radio
If you have an amplifier connected to the radio, make sure the amp remote wire is connected to the blue/white wire and not the blue wire of the radio. The blue wire is for power antenna and is energized only when tuner is playing, not when cd or ext media is played, and therefore will shut your amp off when playing those sources.
Jan 05, 2014 | Kenwood KDC-MP628 CD Player
I just installed my lightly used alpine cdA 105.the radio plays on all speakers but when I try the cd or iPod it only plays on one speaker. Any thoughts.
are you using an amplifier? if so, you may be using the blue wire (antenna remote turn on) instead if the blue/white wire (amplifier remote turn on) to turn the amplifier on. the antenna remote turns off when leaving tuner mode.
Feb 15, 2011 | Alpine CDA-105Ri CD Players
Intermintent stereo in 97 caravan
sound like the tuner it's self is going bad.  Have you checked the antenna connections?  Try holding on to the antenna when the radio is fading out.  Sadly the radio is part of the stereo and not a separate module.  You need a new stereo, get one with HD radio...you'll love it.
Mar 17, 2009 | 1997 Dodge Caravan
I am getting sounds only out of my tuner selection (radio) source
I would start off by doing exactly that removing the black box tuner out of the equation. The next question is did you install the black box or did you have someone else install it for you. If the box is not installed propperly then the audio outs could not be wired up correctly. Double check all of your connections. It could be something as simple as bad or no power to the box.
Mar 01, 2009 | Crossfire VR1000D Car Audio Amplifier
Connection of Amp to Equaliser
Thanks guys, but i solved my problem, i experimented and decided that i would run my DVD player (Aux Out) as a CD player through the Equaliser in [Rec] and from equaliser out [Play] i went into Tape Play on Amp, then i connected my Turntable CD Radio System to the Tape 1 Rec on Equaliser and then from Tape 1 Play on Equaliser went into the Tape 2 on AMP then i could use Aux in on Amp to connect my Laptop via my laptops headphone socket my laptop has an equaliser so i didn't need to connect to pioneer EQ, i also connected a small 5.1 to the DVD's 5.1 and connected 4 *45w Speakers to the AMP. and i can say it was FANTASTIC i couldn't get to 5 on my volume it was un @$#%believable.
My Quote
"Where there's an In, there's an Out".
Aug 30, 2008 | Audio Players & Recorders
Jensen head unit VM9311TS no sound from CD
Should wire HU's Power Const to Amp's Remote On. Instead you wired HU's Power Antenna to Amp's Remote On. So the stock amp got triggered only in radio mode.
Jan 24, 2008 | Jensen VM9020TS Car DVD Player
Kenwood receiver/sub problem
The amp's remote turn-on wire is probably connected to the blue wire coming from the back of the stereo - this is intended for a power antenna, which is why it only works when listening to the radio. Disconnect it from the blue wire and connect it to the blue/white wire coming from the back of the receiver and you should be good to go.
Sep 21, 2007 | Kenwood KSC-WD250 Car Subwoofer
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
